Need help with reverse after valve body
Old 09-27-2015, 05:48 PM
jjmiah217's Avatar
Default Need help with reverse after valve body
I have a 2002 jaguar x type 3.0 automatic 170,xxx miles, I just replaced the valve body and used a matco scanner for fluid temp readings, I added 3 quarts total of fluid, I pushed out of shop and drove 1 mile and pulled back into shop. I had reverse, moved it around some more that day, then left it sit. i went to move it today in reverse and it dosent move, any help is appreciated thanks in advance, sorry for the spelling. Reason for replacement of valve body was had gearbox fault and had limp mode, Jag dealer said it was bad solenoid cheaper to get new valve body.
Old 09-28-2015, 09:09 AM
mrplow58's Avatar
Check your level again. Make sure the fill plug is in ALL THE WAY. If you didn't go through all the gears a few times, especially after after a valve body change, I would bet you are low on fluid now, that things have cooled off.....Just my 2 cents.....Mike
jjmiah217 (09-28-2015)
silkcat
04-15-2023 04:58 PM
bamforp
09-26-2021 08:04 AM
TheWarlock
06-25-2020 05:24 PM
xjrjag
09-27-2015 01:53 AM
ccfulton
09-20-2015 05:15 PM
Quick Reply: Need help with reverse after valve body
