Need help with reverse after valve body
Old Sep 27, 2015 | 05:48 PM
jjmiah217's Avatar
Default Need help with reverse after valve body
I have a 2002 jaguar x type 3.0 automatic 170,xxx miles, I just replaced the valve body and used a matco scanner for fluid temp readings, I added 3 quarts total of fluid, I pushed out of shop and drove 1 mile and pulled back into shop. I had reverse, moved it around some more that day, then left it sit. i went to move it today in reverse and it dosent move, any help is appreciated thanks in advance, sorry for the spelling. Reason for replacement of valve body was had gearbox fault and had limp mode, Jag dealer said it was bad solenoid cheaper to get new valve body.
Old Sep 28, 2015 | 09:09 AM
mrplow58's Avatar
Check your level again. Make sure the fill plug is in ALL THE WAY. If you didn't go through all the gears a few times, especially after after a valve body change, I would bet you are low on fluid now, that things have cooled off.....Just my 2 cents.....Mike
silkcat
Jan 18, 2025 04:29 AM
xjrjag
Oct 24, 2024 03:09 PM
bamforp
Aug 14, 2024 05:36 PM
TheWarlock
Jun 25, 2020 05:24 PM
ccfulton
Sep 20, 2015 05:15 PM
