engine swap 95-97 questions.
Old 05-11-2012, 04:04 PM
XJRengineer's Avatar
I think you are describing the cruise control actuator. if so the link is meant to slide, so that the throttle can be opened by the accelerator pedal without having to compress the cruise control vacuum actuator.
Old 05-11-2012, 06:47 PM
jagdayn's Avatar
Looking at the diagram I'm thinking it may be the supercharger bypass actuator. Does this sound right? And if so what does it do? I've noticed that there's no hose coming out of the back of it either..
-Dayn.
EDIT: I was looking at the wrong thing on the diagram it's not the sc bypass valve. I'm still not sure about the original part in question. I'm thinking maybe it's for a harder feel on the gas petle, or maybe an idle adjust?
Old 05-11-2012, 07:14 PM
jagdayn's Avatar
Xjengineer I think u may be correct. There are no wires or anything going to it.. What does this thing actually do? As I see it there's no way for it to do anything unless the nut is tightened.. Maybe I'm confused haha.
-Dayn
EDIT: I found the vaccume line that conects to the cruise controll actuator, I think I understand it now. This must suck in the actuator thus moving the throttle correct? Also on the vacuumed pump there is a line missing and it wasn't there when I began. It's the one towards the rear. The smaller line is hooked up but the larger one is missing. Any clue? Thanks again.
Dayn.
Old 05-12-2012, 05:50 PM
jagdayn's Avatar
well ive finished putting everything back together and now have some codes. the engine starts but is misfiring bad.. ive got codes p306 and p305 so its misfiring on cyl 5 and 6. there are also a few more codes.. p1199, p1775,p1316, and p1314. any help or suggestions are are welcome. thanks.
Dayn
Old 05-13-2012, 05:17 AM
If you have misfires on both cyl 5 and 6, then you should check that you haven't connected up the harness on these two coils back to front. It is quite easy to get these two connectors wired up wrong as the leads will reach the wrong coils.
Old 05-13-2012, 03:04 PM
jagdayn's Avatar
i was wondering about this. are these the two coils that are closest to the firewall?
Dayn
Old 05-13-2012, 03:53 PM
jagdayn's Avatar
xjengineer your a genius its running good now. i have some other codes but i will prob start a new thread for those. thank you again for all who helped with this rather large project.
Dayn
FrickenJag
09-25-2016 08:00 PM
cissdm
05-03-2016 06:02 AM
sogood
09-15-2015 07:35 AM
bdboyle
09-04-2015 06:16 AM
Bowman
09-03-2015 03:17 PM
Quick Reply: engine swap 95-97 questions.
