Failsafe engine mode
Our 2002 VDP with 68K miles has started flashing the amber FAILSAFE ENGINE MODE warning a few miles after startup. There is no change in how the car runs or responds (as I have experienced when other cars have gone into 'limp home mode). The warning remains until the next startup, when it then reappears after a few miles have gone by.
I am aware of how sensitive these cars are to battery voltage after getting errant TRAC or ABS warnings traced to that problem, but the failsafe issue occurs when the battery is fully charged. The low mileage indicates the car isn't driven often, so I now keep it on a maintainer. It makes no difference how the car drives, but the message worries my wife and obscures the odometer. Any ideas??
On the battery voltage a few thoughts; Not sure how you determine your battery is fully charged, but the only proper way is to actually measure the charge. Most car part stores in the US can do that for you. Next best way is to measure the voltage on the battery with the engine off and engine idling and make sure they fall within spec.
The problem with our Jaguars is that the voltage on the battery could be great, but what happens next. So having clean battery clamps, clean grounds, fuses, connectors etc is really important. Every couple of years I spend a few hours on my XJR cleaning everything that might cause a voltage drop. Lots of information on this forum.
But lets get those codes and take it from there.
Jeroen
