ABS Module repair - not as easy as it seems
I was able to remove the ABS module of my 98 VDP without disconnecting any of the break lines. It was quite easy to remove. I did slightly bend the break lines outward so as to remove the module. I attempted to open the module but had a difficult time. I tried the saw and blade method as recommended by other forum posts. I felt like I was just going to damage the plastic housing. My solution is to send it to Module Master in Idaho for a complete servicing. I find the five year guarantee to be very appealing.
Thanks pdog2000. I sent it off to module master already. I would have liked to solder it myself but just couldn't get past opening the plastic housing. I didn't want to damage the housing any further. I was just happy to have gotten the module out without removing any ABS lines
ABS Module
It wasn't so bad I just followed the directions - on previous posts.
after you disconnect the break lines and remove the ABS module.
instead of a hack saw I used a dremel tool to cut the plastic cover. it was an even cut. then soldered the leads. I just used an rtv gasket maker to seal the cover together. hardest thing was thinking of cutting the plastic abs case. but once you start there is no turning back.
I tore off one of the solenoids when removing the module. The solenoid had corroded onto the valve body.
Module Master was the only place I could find that would fix the solenoid.
They did this and resoldered the posts-all for $100, their normal price! I recommend them highly.
No affiliation.
No affiliation.
Thanks to all for the many threads on this repair, I also have a 98 VDP and was able to bend the lines out of the way, the major problem was getting a deep E5 torx socket in to the two bottom screws with the frame in the way, soooooooooooooooo, I went below and removed that plastic tank (2 screws) and took off the 4 nuts holding the entire abs/pump/module unit to the frame.
At that point I was able to get the 2 lower screws out.
trosty
26
12-18-2022 06:40 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
