Does your VDP have shorter door trim on one side?
Old 03-21-2011, 06:45 PM
dba-one's Avatar
Default Does your VDP have shorter door trim on one side?
I didn't notice this until the other day. The exterior door trim on the passenger side is shorter than the other side. It looks as if it was replaced with a normal XJ8 part and not a L or VDP. Can't be right?
Old 03-21-2011, 07:32 PM
Alvin Burns's Avatar
Trim on my 02 XJ8 VDP is the same on both sides.
Old 03-22-2011, 01:18 AM
vdpnyc's Avatar
not perceptibly... If it is it is a difference of millimeters
Old 03-22-2011, 08:18 AM
dba-one's Avatar
This trim part is about 5 inches too short. Looks to me like someone stuck on the wrong part.
Old 03-22-2011, 09:28 AM
meaculpa's Avatar
On mine are equal. Maybe the previous owner had a fender bender and they screwed up the repair using a trim from the regular XJ8. Just a thought...
Old 03-23-2011, 12:39 AM
vdpnyc's Avatar
5" is exactly the difference in size of the long wheel base, so you solved the mystery.
Lol, how did you not notice a 5" gap right away?!
Old 03-23-2011, 07:51 AM
dba-one's Avatar
I was more concerned with other aspects of the car when buying it so it took me about a week to spot this.
Old 03-23-2011, 09:18 AM
Sinister 1's Avatar
Those are pretty easy to take off. With the door open use a wedge shaped tool that wont scratch the paint (not a screwdriver) and wedge it between the top of the door skin and the trim piece. Gently pry the trim piece upward until you can get your fingers under it and pull it up the rest of the way.
Installing the new one is easiest if you start with the trim tipped down at the front and locate it using the glass and forward edge of the door as a reference. Push the front end down to seat the clip and then tip the rear edge down and seat the clips as you go.
If you buy a used part make sure to ask if there is evidence of corrosion on the back side of the weatherstrip. They are prone to having that issue and if you get a rotten one to start with you'll be buying another one soon.
If you buy a new one let us know what it costs. I know mine will need replacing in a year or so.
Ken
Old 03-23-2011, 04:56 PM
dba-one's Avatar
I'll do something about one day. Right now I need to deal with J Gate problems.
99xk8guy
06-05-2023 06:28 AM
PMKimpton
08-03-2019 08:22 PM
Wolfy
04-06-2019 10:40 PM
GordoCatCar
01-02-2017 01:10 PM
Dicque
09-19-2015 12:53 PM
Quick Reply: Does your VDP have shorter door trim on one side?
