Jaguar xj8 pipe problem
Old 10-29-2014, 02:37 PM
justine3.2's Avatar
Default Jaguar xj8 pipe problem
HI Can anyone please tell me where this component fits.
Part no: AJ84880.
After the dreaded heater house leak, i removed the inlet manifold and never took any notes or photos, ( doh what a mistake) i have replaced the tower and both heater pipes and used some better clips than the std spring type.
Now after the rebuild i,am about to fit the throttle body and after sorting the various pipes can,t figure this one.
Old 10-29-2014, 02:51 PM
dsnyder586's Avatar
Easy-peasy. The long part goes from the front of the drivers side cam cover (special connector plugs into the part-load breather orifice) to the throttle body driver's side (the pipe "t") and the part with the hose goes to the emissions part on the bulkhead in the center.
justine3.2 (10-29-2014)
Old 10-29-2014, 02:52 PM
dsnyder586's Avatar
This applies to LH drive US spec cars- for you across the pond it would be passenger.
Old 10-30-2014, 02:07 PM
justine3.2's Avatar
Thanks very much for the information
Old 10-30-2014, 06:18 PM
dsnyder586's Avatar
Your very welcome! So is it running now?
Old 10-31-2014, 07:41 AM
jimlombardi's Avatar
Received 1,618 Likes on 874 Posts
Here is another JPEG showing the Part Load Breather Hose connections:
Jim Lombardi
Attached Thumbnails Jaguar xj8 pipe problem-2001-jaguar-xj-part-load-breather-hpse-connections.jpg
The following 2 users liked this post by jimlombardi:
D. Fite (11-01-2014), dsnyder586 (10-31-2014)
Old 10-31-2014, 09:28 AM
dsnyder586's Avatar
Thank you Jim, I find your pictures and diagrams invaluable- keep em coming!
Old 10-31-2014, 10:07 AM
justine3.2's Avatar
I had a bad fuel leak from the fuel pressure regulator valve near to the fuel rail, it was my own fault because i never secured the retaining bracket correctly.
So now i have the flooding problem typical of these v8's, better than the situation yesterday with fuel pouring out onto the ground.
So we are getting there, thanks for your help and concern, you were spot on with the pipe work many thanks.
Old 10-31-2014, 10:16 AM
justine3.2's Avatar
Jim Lombardi
Thanks for this information its most helpful, and the jpeg pics mean even i can't get it wrong, i say that a bit tongue in cheek.
Fraser Mitchell
10-01-2015 04:06 AM
MarathonJohn
09-03-2015 07:59 PM
DeaconHull
08-28-2015 05:26 PM
Will P
08-27-2015 06:52 PM
souldoubt
08-25-2015 08:15 PM
Quick Reply: Jaguar xj8 pipe problem
