Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > XJ ( X308 ) XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X308 ) XJ8 / XJR 1997 - 2003
LinkBack Thread Tools Search this Thread
Old 09-28-2012, 04:35 PM
OldMike's Avatar
Default Valve Cover Gasket Replacement - Need How To
I would like to replace the valve cover gaskets, etc. and need two things: (1) where to get the "kit" or parts, and (2) a how-to on the procedure.
I thought there was a thread about this but can't seem to find it. I remember reading the thread because it stuck with me that people were saying that the LS1 parts are less expensive but the same as the Jag parts. I did find a thread with a mediafire link, but the link doesn't work - I think it was supposed to be a step-by-step how-to.
My mechanic told me today that it would cost me $1,180 plus tax for him to do it! YIKES!!!! That includes the gasket, plug seals, and the 14 other parts (what are they called?). Seems a bit (a lot) high to me! He said it would take at least 8 hours, but I would think it could be done in a lot less time than that. I told him no!
So, any help would be appreciated. I have a little experience with working on engines, but I'm no expert by a long shot. I can handle a wrench and follow directions, though.
Thanks for any help or advice.
__________________
2003 XJ8 Zircon
Old 09-28-2012, 06:53 PM
It is the 2001 Lincoln LS1 gasket set, I think. If you have the 4.0L engine that should work. Here is one of the secondary tensioner procedures:
experience & pics of replacing the upper cam chain tensioners(2-post with PICS)How To
If you just need to replace gaskets that is a rather easy job, and should take a couple of hours max. It sounds like your mechanic was quoting you a secondary tensioner replacement at the very least.
RJ_____________
97 XK8 86K mi
Old 09-28-2012, 07:18 PM
That is the 2000, or '01 Lincoln LS gasket set. FelPro has the complete gasket set for less than $40 at your local auto parts store. I would make the assumption the the '14 parts' are the seals around the bolts which are included in the above mentioned set.
This is a one + hour job with a $10 set of 1/4" sockets. Biggest issue I had was removing the oil dip stick tube which is really not that hard. Need further guidance check here:
http://www.jaguarforums.com/forum/ja...17/#post316489
Your '03 car does not need the tensioners replaced.
I would ask your mechanic to tell you that your are stupid to your face before leaving your car with him.
__________________
2002 XK8
2001 Honda GL1800A
1982 Volvo 245 Ford 302 V8
1981 Volvo Bertone Coupe - 25k original miles
The Following User Says Thank You to test point For This Useful Post:
JimC64 (10-13-2012)
Old 09-28-2012, 07:46 PM
OldMike's Avatar
Quote:
No kidding! LOL
Thanks for all the great info.
__________________
2003 XJ8 Zircon
Old 09-28-2012, 09:37 PM
if you can't get them from there, get them on ebay. It seriously is easy! Replace your tensioners at the same time if you haven't since you're already in there. My dip stick wasn't even connected and the valve cover came off without any problems.
Old 09-29-2012, 05:32 AM
Sean B's Avatar
careful not to loose any bolts, the cam cover bolts usually stay in the cover, held by the rubber o rings. I use a magnetic tray to hold the coil bolts.
You'll also need to Loctite Ultra Grey gasket sealant to put a small blob at the timing cover junction.
Also use a torque wrench to tighten the cam cover bolts back down to 9Nm, over tightening can crack the covers (usually once the engine has warmed up and the main reason they leak in the first place).
Good luck, it's a nice easy job
__________________
2002 XJR 100'S' - Better than new.
1964 E Type Roadster
1962 E Type Coupe
1966 MKII 3.4 m.o.d
Looking for an XKR......to modify (evil grin!)
Old 09-29-2012, 06:33 AM
OldMike's Avatar
Thanks again for all the great advice. My first step is to find the gasket kit.
This is my only car, so once I start taking it apart, I have to finish the job -- therefore I need everything before I get dirty!
I found this at partsgeek.com using "2003 Jaguar XJ8" for the search - http://www.partsgeek.com/catalog/200...asket_set.html
And this at Advance Auto using "2000 Lincoln LS 3.9" for the search - http://shop.advanceautoparts.com/web...pro_99992753-p
I know that sometimes the photos/diagrams/drawings aren't exactly what you get, but it concerns me a little that these two kits have some differences. Can anyone help me with the selection?
__________________
2003 XJ8 Zircon
Old 09-29-2012, 06:58 AM
Sean B's Avatar
partsgeek set look to be right, i.e. Jaguar 2003.
__________________
1962 E Type Coupe
1966 MKII 3.4 m.o.d
Old 09-29-2012, 12:53 PM
. . . as does the Advance AP FelPro set.
I am surprised at the price increase. They were less than $40 a year ago but you do get 20% off and free delivery to the store.
Don't own any Advance stock but sure do spend a lot of money there.
__________________
2002 XK8
2001 Honda GL1800A
Old 10-13-2012, 07:05 AM
OldMike's Avatar
Question -- how do I know that I'm getting the right stuff in the gasket set? For example, the JTIS shows spark plug seals that look like O-o-O but the FelPro and partsgeek sets show simple, round seals? Are there possibly two different engines and I need to find the set for my particular engine?
As I said before, I'm concerned because this is my only car right now and I can't afford to tear it apart and then find out I have the wrong parts.
Thanks.
__________________
2003 XJ8 Zircon
Old 10-13-2012, 07:22 AM
The connected center gaskets were used in the AJ26 engines, the earliest version. You can, I believe, use the fel pro set available at most auto parts stores.
RJ____________
97XK8 86K mi
Old 10-13-2012, 06:39 PM
Hi
I purchased the Fel-Pro valve cover set VS50724R (Ford, Lincoln 3.9L Engine DOHC 2000-2006) for our 2001 XJ8 from Rock Auto.com totaled $43.89 (includes $8.44 shipping).
Advance Auto Parts price is $64.00, but if you purchase it online, then apply promo code A123 (discount of $20.00) brings it down to $44.00 and use the pickup option for your local store (no shipping costs & you can go pick it up within an hour or more).
Jim Lombardi
The Following User Says Thank You to jimlombardi For This Useful Post:
JimC64 (10-13-2012)
Old 10-14-2012, 07:49 PM
HEY OLDMIKE...
CHECK THIS OUT... Fel-Pro VS50724R Valve Cover Gasket Set | eBay
UNDER 42 BUCKS SHIPPED TO YOU IN 3 DAYS...I JUST USED THESE ON MY JAG..2002 VDP AND WORKED PERFECTLY...TOOK AWAY A CYLINDER MISFIRE ON MY JAG. WE DID USE SOME SORT OF GASKET SEALANT..CANT REMEMBER THE NAME BC SOME OF THE GASKETS LIKE PLUGGED IN ALMOST WHILE SOME DID NOT SEEM TO STICK THAT WELL..THE BIGGER ONES THAT ARE LIKE 1 LARGE PIECE...ONCE WE DID THAT IT STUCK PERFECTLY. MY DAD WOULD KNOW THE NAME OF THE STUFF IF U NEED IT.
Old 11-22-2012, 06:50 AM
The Fel-Pro VS 50724 R Valve Cover Set includes:
1) Valve cover gasket - Left
1) Valve cover gasket - Right
28) Valve cover grommets
1) Oil tube O ring
4) Valve cover rubber seals
8) Spark Plug tube seals
Jim Lombardi
Old 11-22-2012, 07:47 AM
Photobucket
Send a message via MSN to JimC64 Send a message via Skype™ to JimC64
Click the image to open in full size.
Where are we at with this OldMike?
Are you good to go, do you have enough info etc?
Please update the thread when you can
__________________
Jim
A day without sunshine, is like, well, NIGHT!
Nothing is foolproof to a sufficiently talented fool!!
A fine is a tax for doing wrong, A tax is a fine for doing well......
The things that come to those that wait, may well be the things left there by those who got there first!!
MY2007 Audi A6 3.0 Tdi SE Quattro 176bhp Stratos Blue, Front & Rear park assist, Comms Pack High, Sline grille badge, 19" 7 twin spoke RS4 alloys, Rear tints, Dipped bulbs 80W, Mainbeams 100W, Foglights 100W, Number plate bulb LED's, Interior bulb LED's, First Aid Kit, Bootliner, Mudflaps front & rear, Calipers & hubs painted.
MY2004 VW Passat 1.9 Tdi Highline
LANG MAY YER LUM REEK
**********************Contact-Admin // Forum-Rules // New-member-Must-Read // Vendor-directory**********************
If you've been helped, please click on the "Thanks" button
Old 11-22-2012, 10:36 AM
OldMike's Avatar
I'm on vacation, won't be home for several more weeks, will get back to this project at that time.
__________________
2003 XJ8 Zircon
Tags
2001, 2003, 40, 98, cam, change, cover, etype, gasket, jaguar, leaking, remove, replacement, timing, valve, volvolabor, xj8, xk8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
