Boot (trunk) space?
Boot (trunk) space?
My XK has a space saver spare wheel - I know that the spare was an additional option when buying from new - which implies that they might supply the XK without the wheel and probably a can of that puncture glue stuff instead.
Q: Do these model XKs have more boot (trunk) space? If so - can you convert between the two? I.e. remove the hatch that covers the spare and get something to make it all look pretty?
If our space saver spare(I have one too) is not the same diameter as your regular tires don't see how it will work with the ABS or Traction Control!
Changed a flat on my wifes XK8 with a spare full size with better tread and car went ape; ABS on and off, Tract control warning and then limp home mode!
Anyone tried the space saver spare? and what results?
Cheers, Adrian
Cheers, Adrian
Received 2,193 Likes
And there is a liner than goes down instead of the spare, but why? You can fit a set of clubs in there. And i have a customer that made of a rear seat cover that clips into the back seat area quickly. He and his wife took both sets of clubs, and 2 large soft suitcases with them across country to cali. They even stopped in mina galleries and now mina wants to carry his rear seat cover so call them about it.
XKRs equipped with the optional Alcon brake package do not have a spare tire, since it will not clear the 6-piston front caliper. Instead, they are fitted with a 12v tire pump and sealant, and the tire well is finished out nicely with a molded carpet liner. As a result, the useable trunk space is substantially increased.
