are these essentially the same??
https://tougetuning.com/shop/plx-dev...tooth-adapter/
https://www.amazon.ca/gp/product/B00...k_ql_qh_dp_hza
Please comment as the Kiwi is significantly more but is there a reason?? Want to buy ASAP
ELM327 V2.1 OBD2 OBDII Adapter Bluetooth Diagnostic Scanner Car Vehicle | eBay
- Support for OBD-II diagnostics. Find out why your check-engine light is on and clear diagnostic trouble codes (DTCs)
AllblueACR (11-05-2016)
Strange as normally all generic code readers would give you the code number. As there are several O2 sensors you should be able to get the code of which one is giving you the reading. If you get it again see if you can get a different code reader that will give you the code.
