Luggage Compartment Switch not working
Old 10-27-2014, 09:47 AM
PaulJ's Avatar
Default Luggage Compartment Switch not working
The button on the luggage compartment isn't working (the button in the centre of the chrome strip). I have traced the wiring back from the button to near the security and locking module and I don't have a break and the button works OK.
The luggage compartment unlocks if I use the luggage compartment release on the key fob but if I unlock the car with the fob and then try and press the button it doesn't work. Same if I unlock it with the key in the door lock
The internal release by the steering wheel works as does the release where you put the key in the hole where the XKR is.
Everything points to it being a wiring problem from the button as it unlocks using fob etc. but as mentioned earlier checked that.
I haven't removed the module as hidden under the fuse box but other than checking connections into module (I have made sure they are pushed home) not sure anything else is repairable.
I am hoping its not that as understand they are expensive.
Any ideas much appreciated
Paul
Old 10-27-2014, 12:00 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
When you checked the wiring, was the boot lid up or down? A wiring break could be intermittent and sensitive to the position of the boot lid. A wire break near the hinge is by far the most common cause of this problem.
PaulJ (10-28-2014)
Old 10-27-2014, 01:06 PM
RDMinor's Avatar
Why or how would your unlocking the door with the key or the fob disable the trunk unlock button on the fob? That would seem to me to indicate a problem with the security module and not necessarily a wire break.
Old 10-28-2014, 03:58 AM
PaulJ's Avatar
I think I will check continuity with the trunk closed to be certain it isn't as WhiteXKR suggests.
RDMinor that is my fear and I am not sure if there is a way to check the S&LC module from what I see from JTIS pin 5 is taken to earth when you press the trunk switch button. Do you know if it's easy to take the module out (just the 2 visible bolts) as it is hidden under fuse tray?
Old 10-28-2014, 05:49 AM
jamdmyers's Avatar
Make sure you are not in Valet Mode.
Old 10-28-2014, 04:18 PM
PaulJ's Avatar
WhiteXKR you were right it was a broken wire which oddly didnt show up when trunk open.
The cable covering was intact but conductor had broken. Very odd there were 4 cables in the sleeve but only one broken and no obvious physical damage.
I was able to feed another cable through plastic sleeving and solder to existing.
Many thanks
WhiteXKR (10-28-2014)
D.K
12-10-2023 02:05 AM
allenman85
05-10-2021 03:11 PM
philwarner
09-05-2015 10:05 AM
arnoldmilk
09-03-2015 07:42 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: Luggage Compartment Switch not working
