Should the radio antenna retract entirely into the fender
Old 09-23-2017, 06:56 PM
Barry_Tucker's Avatar
Default Should the radio antenna retract entirely into the fender
or should it stick up a foot or so ? Mine extends quite high when the radio is on, but still sticks up a foot or more when the car is off
Old 09-23-2017, 09:20 PM
Orthodixie's Avatar
My '04 retracts all the way.
Old 09-23-2017, 10:08 PM
baxtor's Avatar
Received 1,123 Likes on 731 Posts
Does your antenna motor assembly make any strange noises at the upper limit of travel? ( like a slipping or ticking)
The "timing" between mast and drive spool may have been upset. Has there been any mast replacement or other work in the past?
Old 09-24-2017, 09:41 AM
grantorino62's Avatar
Not retracting fully is either a bent mast section or left over piece of cable within the motor after a mast replacement.
Old 09-24-2017, 09:54 AM
Johnken's Avatar
Received 1,808 Likes on 1,115 Posts
+1 on Gaterino's comments. As I recall a dirty antenna can be a suspect too.
John
Old 09-24-2017, 11:17 AM
I'm thinking that the previous owner was a bit of a twit. He said that the car only had a cassette player but it does in fact have the cd changer in the boot. A close inspection of the aerial indicated that it had been bent badly once before and someone tried to straighten it ....guess I'll need to replace it eventually.
Old 09-24-2017, 11:51 AM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Turn the radio on to extend the antenna then spray the antenna with WD40 and work it up and down the antenna then wipe it clean and the repeat the process. After you do that 2 or 3 times turn the radio off to retract the antenna and help it retract without bending it. Do this a few times wiping it clean between operations. Often dirt will cause it from retracting property. See if this helps the operation.
Gus
www.jagrepair.com
Old 09-24-2017, 03:12 PM
Will try it but I think it was badly bent and then poorly straightened. I expect I will have to replace it
Old 09-24-2017, 10:20 PM
If it has a noticeable kink at any mast section, replace it before it breaks the nylon cable within the motor. The first week I owned mine, I disconnected the power lead to it. I listen to CD's and Pandora only.
Old 09-27-2017, 01:11 AM
RobXK8's Avatar
When I bought mine the seller said it wouldn't go down. I never listen to radio, so instead of fixing it I just shoved it down all the way in. Super cheap fix lol
Old 09-27-2017, 07:52 AM
mine was bent and would not retract fully when I bought the car. I got a replacement ($15) and figured out how to put things together (there is at least one good youtube vidoe that shows most of how to do this). The antenna now goes up and retracts fully.
I enjoy the sound of the road so much that I rarely listen to the radio :-)
Old 09-28-2017, 08:04 AM
I drive with the top down when I can , but almost always have the radio on. Thanks for all the replies folks
