Rough ride after transmission rebuild (97 XK8)
Old 07-23-2014, 11:11 PM
Andre's Avatar
Default Rough ride after transmission rebuild (97 XK8)
Had the transmission rebuilt on my 97 xk8 at a tranny shop in LA (not a Jag spacialist) after the infamous A clutch failure. Before that the car was running perfectly and shifting up and down smoothly, but ever since the rebuilt the car is randomly "jumpy" on downshift and have shut down several times when coming to stops as well as when slowly reversing when parking showing a "engine stalled" message" that goes away when the car is restarted.
I went back to the shop but had been told it has nothing to do with the transmission and that I should check for engine issues... needless to say I'm not convinced since I had none of those issues until then.
They did a scan and found no codes, however, they did confirm they did not reset either the ECU or the TCM... is that a necessary step? Does anyone have any suggestion on how to proceed from here?... By the way, the car has 83k miles.
Thanks!
Old 07-24-2014, 02:55 PM
oldmots's Avatar
When a tranny gets pulled, there is someone in there messing with a lot of things. It's possible that something got disconnected or reinstalled improperly. Its probably their fault, you just have to prove it! Get a powerful flashlight and look for loose connectors or something out of place. Poor idle can be a vacuum leak so look for loose vacuum hoses . Doing it yourself seems unfair, but their guy could be a klutz, keep him away.
Old 07-24-2014, 04:36 PM
oyster's Avatar
Hi.
I had my transmission replaced and was not pleased with the initial results.
- Rotary switch had to be changed.
- Poor idle, air leak, seal btw. throttle body and air intake not properly installed.
- Engaging cruise control gave Check Eng. Light and poor performance warning. Tiny vaccum line on right side of throttle body not connected.
- Gear shift stuck in park. Corrected itself without intervention.
- Poor shift quality, but this is getting gradually better. May be some kind of adaption process.
Old 07-24-2014, 10:05 PM
Andre's Avatar
Well... He offered to call a guy he knows who is a technician at a dealership to check the car, so I guess he's idea is that I can pay someone he recommends to figure out and finish what they couldn't do properly.... so yes, I'm likely keeping him away.
Unfortunately I don't really know how to check for all this stuff properly so I'll probably have to take it to someone else to look into it for me :/ I'm wondering if taking it to the dealer for a diagnostic would be worth it.
tomsjag
06-10-2023 10:02 AM
Bcrary3
02-21-2023 04:29 AM
aholbro1
08-05-2021 05:02 AM
GordoCatCar
01-02-2017 01:10 PM
Bowman
09-03-2015 03:17 PM
Quick Reply: Rough ride after transmission rebuild (97 XK8)
