Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
03 X-type ISO harness Aftermarket Deck install
Old Dec 24, 2008 | 09:07 AM
Tommy K's Avatar
Default 03 X-type ISO harness Aftermarket Deck install
Ok I have my Din kit and my antenna adapters, now the ISO harness http://www.nexxia.co.uk/Car_Stereo_f...s/PC2-81-4.jpg
Now on other cars it has the wires without a harness attached so I can wire it to the aftermarket deck. Am I missing a harness? Or do I splice anything into the ISO? Please help the radio is driving me nuts.
Tommy
Old Dec 24, 2008 | 09:57 AM
christo's Avatar
Default RE: 03 X-type ISO harness Aftermarket Deck install
Something doesn't look right there. Most aftermarket radios do not have a harness - just loose wires hanging off the back of the radio. Looks like you will need something to connect to the cars harness and then there should be loose wires from that harness that can be connected to the loose wires hanging off the after market radio.
Old Dec 24, 2008 | 11:38 PM
Tommy K's Avatar
the ends are what go into the back of the deck now i figured it out I could either make sure it plugs in the back of the aftermarket deck. Or I could cut off the ends and wire it from there.....
Old Dec 25, 2008 | 08:18 AM
christo's Avatar
Did you cut off theharness or are there loose ends? If you are going to wire it up, just make sure that none of the wires get crossed and all intended wires go to their respective counter part.
Old Dec 25, 2008 | 11:11 PM
Tommy K's Avatar
Problem solved I just cut the two end harness'es off and just rewired it to the aftermarket decks wires. Just matched the colors and whalaaa it works!
Old Dec 26, 2008 | 07:34 AM
christo's Avatar
Glad to hear everything worked out! Do you have any future plans for you stereo system?
Old Dec 27, 2008 | 10:54 AM
Tommy K's Avatar
Yes Im using my system I have layin around, a 10" RE se series sub with box made to specs, Kicker 750.1 amp, Treo 6.5 Components for the front and rear doors.
Kevin Burnaby
Jun 28, 2020 08:04 AM
copyman01
Nov 1, 2015 01:01 PM
Darrenmb
Sep 9, 2015 09:31 PM
Harry Dredge
Sep 3, 2015 03:04 AM
