Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Audio Connectivity Module: Slow to initialise all of a sudden
Old Jan 16, 2014 | 06:31 AM
amoeba's Avatar
Default Audio Connectivity Module: Slow to initialise all of a sudden
My ACM used to start playing from my USB stick immediately after ignition. However recently I deleted some files off it, and all of a sudden when I start the ignition the stereo turns to radio, and if I try and select CDC it comes up with 'CDC ERROR' for about 15 seconds until it will change to CDC.
I've tried the Gateway Indexer, and no improvement. Any ideas?
Old Jan 16, 2014 | 03:15 PM
veffremov's Avatar
Does your USB stick have any issues? Flash memory sometimes fails so it may take a while for the module to get past the bad sectors.
Old Jan 17, 2014 | 02:51 AM
amoeba's Avatar
Hmm I guess I can test using another usb stick. Will report back in due course!
Old Jan 21, 2014 | 06:51 AM
amoeba's Avatar
I tried a different usb stick - still the same.
I am wondering if it could be a low battery causing this. Its showing as having only 11.8v without the engine running (14 with engine), so I am thinking perhaps this is causing the ACM to be slow initialising.
Will report back when new battery is on.
Dz1rfj
Jul 17, 2018 10:29 AM
eurotire
Sep 18, 2015 07:27 AM
Dz1rfj
Sep 16, 2015 03:44 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
Mosers63
Sep 6, 2015 02:53 PM
