Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Kenwood DNX9140 install advice
Old May 4, 2010 | 06:19 PM
CDNJagnut's Avatar
Default Kenwood DNX9140 install advice
This weekend I'm planning on finally installing a Kenwood DNX9140 in my 2004 S-type. Does any have installation advice for me? I have all the patch cords, etc. but I'm wondering if there are problem areas that I need to be prepared for. Thanks!
Old May 13, 2010 | 08:42 PM
cobra29's Avatar
Be careful, I read some bad reviews on the 9140 in regards to the navi system. (street names)
Old May 30, 2010 | 03:58 PM
CDNJagnut's Avatar
Thumbs up Install finished
So far I love this system including the navigation system. Not sure about the street names issue. I've had Garmins before and this one seems no different. Install went very well and finished in just under four hours. It sounds great with the factory speakers but I think I'll change them over the summer. I'm also going to add the rear camera and the traffic antenna.
Old Jun 6, 2010 | 08:37 PM
edlaudio's Avatar
Did you also install a steering wheel remote interface? I had a local installer put a Kenwood DDX714 with the KNA-510 navigation and Sirius radio add-ons into my 2004 S-Type and he couldn't get it to work with the Autoleads unit which was recommended on this forum - he tried for about two hours but had to give up and took the Autoleads out.
Old Jun 6, 2010 | 10:39 PM
H20boy's Avatar
My PAC SW1 (i think thats the right model) works great on my xk8 and aftermarket deck, keep trying, its not rocket science to get the steering wheel controls to work.
Old Jun 7, 2010 | 06:34 AM
CDNJagnut's Avatar
Default Plug 'n Play
I installed the Autoleads PC99-X47 Kenwood OEM remote control adaptor. It worked immediately and I'm really happy with it.
Old Jun 12, 2010 | 07:42 PM
edlaudio's Avatar
On your unit did you use the single blue wire or the four pin din? - mine uses the single blue wire only for the lower spec model
Old Jun 13, 2010 | 09:53 AM
CDNJagnut's Avatar
I used the single blue wire, soldered it together and covered the joint with a heat shirk tube.
hope this helps.
Old Jun 13, 2010 | 10:26 AM
H20boy's Avatar
CDN, just letting you know your link above is bad.
Dz1rfj
Jul 17, 2018 10:29 AM
42Ajd
Dec 30, 2015 09:45 AM
42Ajd
Sep 21, 2015 07:37 PM
Dz1rfj
Sep 16, 2015 03:44 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
