Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Replacing speakers in X-Type
Old Jan 5, 2008 | 06:16 PM
aquill1's Avatar
Default RE: Replacing speakers in X-Type
Hey there firebird I'm pretty sure that you remove the door panel and they are in the door but I could be mistaken...let me see if i can find some faqs for you...
Old Jan 12, 2008 | 05:53 PM
FactoryJaguarTech's Avatar
The front door panels are held on by two phillips head screws at very bottom of panel and one behind the door pull handle. You need to pry the cover off. Next grab the top corner and kung fu it off the door. Make sure you note door latch cable routing. Be careful because those door panel clip holders break easy.
Rear is the same but only one phillips at bottom and the one behind the door pull.
Speakers unscrew from door itself. 3 phillips heads. I believe they are 5 1/4 " but maybe wrong.
To install new, you may have to remove the speaker then the speaker housing. You will definitly have to cut the factory connector off and put new connectors on to fit to new speaker.
I put a set of MB Quart speakers into a customer car with the factory audio unit and it sounded very good.
You didn't state year of your X-Type, however, these wire colours are for 2002 & 2003. Maybe the same for later years also. If not, repost and I can give later years. Diagram doesn't show + or - so I will list pin 1 or 2 eg: lhf (left hand front) wg/1 white wire with green trace pin 1.
LHF Yellow = 1 White = 2
LHR Yellow/Blue = 1 White/Blue = 2
RHF Yellow/Red = 1 White/Red = 2
RHR Yellow/Red = 1 White/Green = 2
One could assume that pin 1 would be positive. Depends on your belief of theory Positive to Negative or ViceVersa.
Hope this helps.
Old Jan 13, 2008 | 11:21 AM
aquill1's Avatar
If I'm not mistaken there is a faq on the forum for changing out the door speakers step-by-step...Here's the linky...
Old Jan 13, 2008 | 02:00 PM
My god, was that guy on the link wearing a sweater? Living in So Fl, I haven't worn one of those in years.
Oh how I wish for a cold day.....nice link!!!
Old Feb 19, 2008 | 09:20 AM
mr.xtype's Avatar
FactoryJaguarTech
The MB Quart speakers you put into a customer car, were they a component set with tweeters?
I had a set of 6.5 and want to put them into my 02 2.5 X non premium and dont know whereto put the tweeters. I really do not want tocut the door panel, I was thinkign of that little triangle above the door there in some cars the mirror adjuster would be. Just wondering if anyone hasbeen done before with good sound quality, or do you need to purchasedifferent triangles?
Also the premium sound X has tweeters anyone know where they are located? I amassuming it is in the triangle thingy, anyone know if this is correct and also is it better to buy the premium X triangle or is it fine to just cut mine?
I am looking for a nice clean look.
Old Jul 5, 2010 | 02:25 PM
rf69's Avatar
Mine is a 2004 X type 3.0 V6
My front and rear door passenger speakers are bad and I do not find a OEM Alpine speakers replacement due to that they are wired harness I guess I have to make some changes to get new ones attached to the cable harness from the doors.
Any advice?
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
