Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Subwoofer install options for 2012 XF (base model)
Old Sep 27, 2012 | 11:24 PM
ilwill77's Avatar
Default Subwoofer install options for 2012 XF (base model)
Hello all,
Just wondering what my options are in regards to installing an aftermarket amplifier and subwoofer in my 2012 XF (base model)? Do you know where I can tap into a pre-amp full range signal? Or is there a subwoofer output I can utilize? What would you use for the remote turn-on? I would like to do it right the first time without hacking up the car. Any advise is greatly appreciated.
Thx,
Will
Old Oct 29, 2012 | 05:15 PM
ArnoldKay's Avatar
Definitely looking for the same answer here. I found this thread and saw that JJSAustin was able to successfully install an amp in his 2012. But I'm a bit confused on how to do it.
https://www.jaguarforums.com/forum/x...-system-61827/
I see you're in NJ. If you get this done, would you mind doing it for my car as well? Or provide a detailed description? I'd like to just add a simple 6" sub or a powered amp like this Blaupunkt.
Blaupunkt 6902A GT Power Series dual 6"x9" powered subwoofer at Crutchfield.com
Old Dec 26, 2012 | 12:47 PM
quanva's Avatar
Well any audio system can have a sub added on..I added a shallow mount sub to the dynaudio system in my Vw..Granted it took the shop 2 DAYS to figure it out but it's done
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
AL NZ
Sep 4, 2015 08:39 PM
