Fault Code 44 Fuel
Old Dec 27, 2015 | 08:32 AM
ubetido's Avatar
Default Fault Code 44 Fuel
Hi my 92 3.2 Jag has conked out and I had to have it towed home. I have a fault code 44 showing. Looking at my manual it says it is the oxygen sensor that is faulty. I am not very bright when it comes to mechanical work. I live at Currimundi and was wondering if someone knows of a mechanic in my area who could fix my car.
Old Dec 27, 2015 | 08:41 AM
Welcome to the forum ubetido,
I'm on the other side of the World so can't help with mechanics in your area. However, code 44 is a regular on the XJ40 and this thread will give you some further information which could avoid you having to use a mechanic to fix it:
https://www.jaguarforums.com/forum/x...il-44-a-60195/
Old Dec 27, 2015 | 03:15 PM
34by151's Avatar
By the sounds of it you may not be able to work on the car yourself.
Is the car driveable?
There are a number of members on the coast that may be able to assist you in fixing the issue otherwise recommend a repairer
As GGG recommended first drop by the new members area then do a bit of reading on the issue. After that get back to us with what assistance you need as we would like to see you up and running and possibly on some of our outings
34by151
Old Dec 27, 2015 | 04:23 PM
o1xjr's Avatar
Welcome ubetido, I have added you to the Qld roll call thread. Check out the Qld forum, there are some threads there with links to specialists on the northside of Brisbane.
And as 34by151 has mentioned, possibly other members able to assist in your area.
https://www.jaguarforums.com/forum/a...4/#post1371593
Australia - Queensland - Jaguar Forums - Jaguar Enthusiasts Forum
http://api.viglink.com/api/click?for...shop.com.au%2F
http://api.viglink.com/api/click?for...Rover%20Albion
Old Dec 29, 2015 | 02:38 PM
StuG's Avatar
Give Rob a call.
Caloundra Suspension & Mechanical Centre
13 Daniel Street
Caloundra Qld
Contact Rob & Lynn
07 5491 6355
caloundrasuspensioncentre
@gmail.com
Repairs & Service all makes
4x4's,Modern,European,Classics
Cheers,
Stu
LstFord
May 28, 2022 07:26 PM
Jennifer S Flavell
Feb 5, 2016 04:03 PM
Ubad2
US Northeast
Jan 2, 2016 02:49 PM
chris-jag
Dec 31, 2015 07:02 AM
Roger Mabry
Dec 26, 2015 07:58 PM
