Blown CM
Hi all
I have a 2001 S series 6cyl 3.0L
The Body Control Monitor has blown up
Not just failed but failed spectactularly
Car won't start. Following a weird sound, EVERY single warning light came on simultaneously.
Long story short I've been off the road for 6 months
I did find one for $100 but it's from an 8cyl, not a 6cyl and am unsure of its compatibility
Can anyone here help?
Either with a CM for my exact model, or info on what other CMs are compatible?
Hi
The standard advice is to post on the model specific forum for the S series. This will get you more knowledgeable eyes on your problem than posting at State level in Australia.
Cheers, Steve
Cheers, Steve
Normally when you spray duplicate posts across multiple forums its frowned upon, but its obvious here you arent doing that and the post is just misplaced so post away in the S Series area. The mods here are pretty common sense people from what I have seen and will see that this post is done (no need to delete) and one created in the hopefully more productive area.
Good luck
Good luck
Gavin
give me a call, on 0447441250.
I have a 2001 3.0lt s-type I am wrecking for panels as spares for my car. I have no use for the BCM and you can have it for free.
I am located in Gippsland so not that far from you.
I passed the info you gave me on to Norton Ford Stawell.
They have my email
Now a case of wait, I guess
Gavin
Ta RAAFBOY. I'll be sure to if my current plan goes haywire.
Gavin Quick
Jun 13, 2023 08:27 PM
