X type suspension???
Old Sep 10, 2020 | 08:21 PM
Stephesm's Avatar
Default X type suspension???
Anyone out there found a fix for the incredibly poor suspension system on the X Type. Love everything about the car except the suspension. I can feel every bump in the road. I know there are people who will say it is because it is a sports model but this is ridiculous. I have changed the rear shockers with the recommended Bilson type but it has made no difference. Have thought of increasing the tyre size to 60's but was told it would void my insurance.
ANYONE HELP!!!!
Old Sep 10, 2020 | 11:29 PM
Tijoe's Avatar
The X-type suspension is what it is. Perhaps your suspension has become worn out and many of the bushings and joints need replacing.
What diameter wheels are on your car? 16s, 17s, 18s or larger? The lower the profile tire the harsher the ride will be.
I have 18s on one of my Estates, and 17s on the others. I can feel the ride difference on the 18s.
I've found that the X-types have a decent combination of smooth ride with decent handling overall. *Compared to other AWD cars of its day.
Old Sep 11, 2020 | 01:07 AM
Stephesm's Avatar
It has 16 inch wheels, is it O.K. to fit higher profile tyres?
Old Sep 11, 2020 | 09:47 AM
Tijoe's Avatar
Yes, one can put on higher profile tires,but 3 things will affected.
1. Your speedometer will no longer be accurate.
2. It will raise the ground clearance by 1/2 the height difference between the original outside diameter of the old tire and the new tire. Can/will slightly affect the CG and cornering of the car.
3. Depending on how much higher of a profile you use, the front tires may start hitting your fender liners, and if large enough a tire diameter increase, perhaps start rubbing on the ID of the fenders. Rear tires might start hitting the rear liners when you have passengers in the back and you hit a bump and the suspension compressed all the way to the bump stops.
Old Sep 11, 2020 | 07:02 PM
yarpos's Avatar
You might get more infomed eyeballs on your question by posting in the X type forum area , rather than this regional one. Just a thought.
Old Sep 11, 2020 | 08:03 PM
Stephesm's Avatar
Thanks for the details, I might try going from 55's to 60's next tyre change. Trouble is I was used to an SUV which I believe is better suited to rough roads.
Anyway you have been a great help
Stuart
Dominic555
Feb 6, 2020 09:46 PM
FilmDori
Jun 3, 2015 09:07 PM
jameslake87
Mar 25, 2014 09:44 AM
nmbrwun
Oct 18, 2011 09:43 PM
Adam Lueb
Aug 30, 2010 09:44 AM
