car wax
Old Nov 14, 2009 | 07:09 PM
srjag's Avatar
Question car wax
hey guys i was wondering if anyone can explain to me how to tell if a wax is abrasive or not? i heard that abrasive wax takes off paint/clear coat so i want to find one that is safe to use so i don't lose a layer of paint every time i wax. thanks in advance
Old Nov 15, 2009 | 08:49 AM
user 2029223's Avatar
Banned
I'm no expert on this stuff but I always thought that products labeled "polish" or "cleaner" contained a very mild abrasive. Productes labeled Pure wax usually don't contain abrasives.
A carefull reading of the fine print on the containers usually tells you all you need to know. It does seem that the fine print is getting smaller by the year but it could be my 3 score and 10 eyes too.
Old Nov 15, 2009 | 07:05 PM
srjag's Avatar
yeah i thought so too but i guess i was wrong because i read on a few car detailing forums that if a wax leaves a white residue than it is abrasive.i do not know if its true so that's why I'm asking. i guess i just want to know if Eagle one nanowax paste is abrasive or not. any help would be appreciated
Old Nov 18, 2009 | 02:35 PM
mosesbotbol's Avatar
Pure wax will never contain abrasives. One step or "polish waxes" will contain either a chemical or grit abrasive.
If you have an "open coat" paint job. Paint that is a solid color without clear coat, you can use a chemical abrasive polish like Meguiar Machine Glaze and that will only remove the oxidized paint which is what you want in that instance.
The fine abrasives in most clear coat or hand glazes are so minimal, it's usually just taking the leading edge of a scratch or just dirt in the paint.
I would not worry either way. Use a clay bar and then wax and that should take care of you unless you want to take out the leading edge on sratches or have stuff the clay bar did not pick up.
Old Nov 18, 2009 | 02:37 PM
Not if it is pure wax. Not sure about the product you are using, but it should be safe. Best practice is to put on the wax very thin and not let it sit very long before removing the wax.
Polishes it's generally ok to leave on a section longer so you could do a quarter of the car at a time and wipe off.
Old Nov 18, 2009 | 07:49 PM
srjag's Avatar
ok that really cleared things up thank you mosesbotbol for that information
Old Nov 23, 2009 | 03:45 PM
PSU 98's Avatar
The only ambiguously labeled wax product with some abrasiveness I can think of off hand would be Meguiar's "Cleaner Wax". Other products that are called "wax" are generally just that, some form of paint protectant.
Old Nov 29, 2009 | 08:23 AM
Delta66's Avatar
Lemheantyfate, all I can think of is some cars come with a lacqure coat that in effect is a permanent wax coat. So waxing is not needed. Otherwise every car I have ever had has been waxed within a day or two of getting it. I use Autoglym Super Resin Polish, which I find will last a year between coats.
Old Nov 30, 2009 | 01:54 PM
Hogwash! You can wax a brand new car no problem. You're suppose to wait on recently sprayed paint from the autobody; that's all I know of. I think even that is related to just polish, not wax
Open coat paints (no clear coat) will pull off oxidized paint when polishing.
All wax does is keep the paint from oxidizing. It does not polish or feed the paint.
jdzubas
Oct 4, 2015 09:14 AM
aode06
Sep 2, 2015 12:00 PM
Jandreu
Aug 29, 2015 07:31 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
