Wolfgang Über Compound - All I can say is WOW!!!
A good friend of mine picked up a very nice 2006 BMW 650i conv. The car was in great mechanical condition with low mileage but was let down a tad by all the swirls and scratches in the paint.
I said I would have a go and detail it for him. I had been itching to use my new Wolfgang uber compound and thought this would be a great test. After all it is just a Bimmer
The scratches and swirls were so numerous and deep that I knew I would have to use a fairly aggressive approach. I applied the Wolfgang with my GG6 D/A polisher and a yellow CCS pad. The product was very easy to work and after completing a section with 6 passes, the product wiped off really easily and I was stunned by the amount of correction. I performed a second section pass and the defects had all disappeared!
What was even more amazing to me was that the finish was so good, with virtually no marring to be found. I had been using Meguiars M105 for heavy correction work and although it is a great product, it always seemed a bit finicky to me and didn't finish down nearly as well as the Wolfgang.
The other thing I liked a lot was that it didn't dust too badly. I gave my pad a brush after every two or three sections and dust was a minimal issue.
all in all it's a tough product to beat. Super easy application and removal, fast cutting capability, low dusting and it finishes down very well indeed.
Here are a few pics before and after compounding. No polishing done, just an IPA wipe down.
Front fender scratches and swirls
Fender after compounding
another shot of fender after compounding. NO polishing
Really ugly scratches on the bonnet let down the side.
Bonnet after compounding. I say again, this is ter application of the compound with a yellow cutting pad. To my mind the finish is great, can't wait to see what it's like after I polish it
tberg (12-26-2013)
Thanks for sharing that! An amazing product indeed that I will certainly try if I come across a car that is that damaged. I was not impressed with the GG Machine Polish 1 for cutting. It dusts like crazy and is way to mild IMO.
You do realize that with results like that you are going to work your self into a new job after the word gets out!
I've never tried the Griots polish but the M105 is somewhat of a standard bearer in the industry from what I've read and indeed it does work very well. However, the Wolfgang just flat out beats in every category (except price ). The fact that it finishes like a polish is amazing to me. I will try it with an orange pad and it would not surprise me if you could then go directly from compounding straight to your LSP!!
In any case I will definitely not bother with an intermediate polish and will just go with a fine polish (Wolfgang Finishing glaze). I think the car will be transformed. Will post some pics when I'm done.
LOL!! As I'm retired it has become a bit of a hobby along with working on the maintenance of my cars.
Received 9,005 Likes
Not yet, I've been working through all the maintenance issues and getting the VDP sorted but I will be doing a full on paint correction when that's out of the way
I'm pretty sure the uber compound will be close at hand
Hey Alan G,
Beautiful results! It is nice when a product really delivers and makes the job so much easier. I have a question for you.
In your posting you had said that this car had some deep and serious scratches, etc.. What would you have used if the scratches and blemishes were not so deep and obvious? Does Wolfgang have a milder compound or polish for dealing with less serious damage? I have been using the Meguiars Ultimate Polish and Ultimate Compound that you can buy in any auto store and I find that I need to work too hard with those products. I have also been using the GG polisher but with a Lake Country orange pad. Is the yellow pad more aggressive? Thanks and have a good Holiday.
BTW- up here in New Jersey when it gets cold I have been experimenting with a couple of rinseless/waterless car washes. So far I have used ONR which is mixed with water and Eco Touch which is already pre mixed. I am really careful and have not caused any damage but I find that both products leave like a white haze on paint that is really difficult to get off even with using good micro fibers. I have done this in my garage on fairly cold days when humidity was high. Someone on another forum suggested that when I wipe the car down to dry that I use a dampened cloth instead of a dry cloth. Do you have any experience with these kinds of washes? Thanks again.
Ed
Ed
JeremyB (03-05-2019)
Yes, Wolfgang has a light cutting compound called Total Swirl Remover 3.0 that works well for swirl marks and light scratches. As you should always use the least aggressive method to remove defects, this would be a good place to start and then move up to a more aggressive compound if necessary.
I have been using the Meguiars Ultimate Polish and Ultimate Compound that you can buy in any auto store and I find that I need to work too hard with those products. I have also been using the GG polisher but with a Lake Country orange pad. Is the yellow pad more aggressive?.
As a newbie I found that I initially used too low a speed on my GG6, too little pressure on the pad and too fast an arm speed. This combination will significantly reduce your cutting ability and that means more work!!. You really do need to use at least speed 5 on the GG, 6 is even better. Also, I put my GG6 on the bathroom scales and practiced what putting 20-25 lbs of pressure on felt like. During use, I constantly reminded myself to slow down my arm speed. You really want to creep along the surface so that the compound and pad can do their magic.
My process for using rinseless washes is to put about 2 gallons of distilled water in a bucket with the appropriate amount of RW concentrate (I really like the Pinnacle product). I then put about 12-15 mf towels folded in four into the bucket to let them soak in the solution. I then take out two of the towels and wring them out as much as possible to use as the initial drying towels.
To wash a panel, I spray the area first with a light mist of waterless wash, then taking a wet towel from the bucket, I make one straight, continuous wipe along the panel, rolling the towel with my hand as I wipe. After each wipe I flip the towel to a new side and do another overlapping wipe. Once I have used all the sides of the towel (one wipe per side) I toss the towel in an empty bucket and then take one of the wrung out towels and use that to wipe over the washed area to dry it. Finally I follow up with a dry, soft, thick mf towel to buff the area. I then move on to the next panel with a new wet towel. I have found that this technique works really well provided the car is not too dirty and gives you the least possibility for instilling swirls. If you have caked on mud for instance you would want to wash the car with a spray hose first to knock off most of the dirt.
LnrB
09-24-2015 11:16 AM
