Diesel variants - All models Visit here for discussions on diesel powerplants and the impressive torque / mpg figures achievable....
EGR unit
Old May 12, 2018 | 12:48 PM
warbie's Avatar
Default EGR unit
x type jaguar 2lt diesel diagnostic check show egr problem i took it of and replaced it but still shows on diagnostic tool
Old May 13, 2018 | 09:22 AM
Man on the hill's Avatar
What code does it throw up ?
Paul.
Old Aug 11, 2021 | 10:25 PM
Mooltan's Avatar
Has anyone had coolant loss INTO the egr unit. My coolant level is dropping without obvious leak. So this means egr or head gasket or similar. Is it possible to detect coolant leak in the exhaust gases ???
Old Jul 17, 2025 | 01:27 PM
Just Me's Avatar
Lightbulb could be
Just a general list
EGR cooler, turbo inter cooler. turbo if water cooled. engine oil cooler. Transmission oil cooler. Heater core.
Old Jul 17, 2025 | 02:21 PM
Vasara's Avatar
Check your transmission oil level immediadly in case your trasmission oil cooler have been failed and coolant is entering to the transmission.
Also engine oil cooler sitting middle of engine can leak to the V where it vaporites without shoving the leak. Naturally you have check the engine oil cap for moist? Have you?
EGR coolers are possible, but not very common on AJD-V6.
There are one plastic part what somebody have been reported failing on middle front of the engine called: Engine Water Outlet.
On some engines this part last forever and some report it failing often. Now it seems that the original part last, but these mechanics who change this part during timing belt work, "because when in there" and use non-original part, may cause issues later by failure.
Also check under your front interior mats in case you have an heater leak.
Turbos or intercooler are not involved with coolant on AJD-V6
Chris Russell
UK & Eire
Jul 24, 2025 03:15 PM
chewyshaun
May 21, 2019 03:59 PM
harryxtype
Mar 3, 2018 12:56 PM
gtoast99
May 13, 2015 07:49 PM
03Xtype
Jan 27, 2012 11:07 AM
