E-Pace 2018 - Onwards
Gearbox Fault warning - issue with TCM
Old Jul 22, 2024 | 03:31 AM
Hmc279's Avatar
Default Gearbox Fault warning - issue with TCM
Hi I purchased a 2019 E Pace P200 back in September last year and have had no issues since then, until a week or so ago when I went to start my car and could not get the engine to start On the dashboard it flashed up Gearbox fault and after several failed attempts to start it I had to call my local garage. They were able to get it to start by taking the shifter casing off and doing something manually, and managed to drive it to their garage. They have since told me that it is an issue with the TCM, which at first they reprogrammed and stated that the car was running like normal again during several test drives. I picked the car up and lo and behold, 25 mins later it happened again. This time I had to be towed to the garage, who have since told me that they are going to need to replace the TCM with a new one, at a cost of circa £2,500. My Jaguar warranty expired in January and I am about 700km over the dealer warranty, so at present I am on the hook for this bill. Given the car has only done 60,000km I am just surprised at how something so fundamental could fail at such an early stage... has anyone else had this issue ? The garage has noted that this is a common issue with this car and I might be able to get it repaired for free via recall but I have no idea how to check this Any help much appreciated! Thanks
Old Jul 26, 2024 | 07:40 AM
DanDenver19epace's Avatar
All dealers know how to research what recalls apply to your vehicle. Just make an appointment.
Similarly, most makes keep a ‘recall’ website. Since I have no idea where in the world you are, I will only produce the website for USA: https://www.jaguarusa.com/ownership/vin-recall.html
Note that recalls often vary by country
Also, your dealer is your best resource for up to date recall info. I would not trust the website for something so concerning.
No matter how you proceed with this research, you will need your VIN, so make sure you have it readily available.
New2Jag
Mar 26, 2025 04:58 PM
Jag1181
Jan 2, 2023 10:29 AM
campaign308
31
Dec 30, 2019 09:04 AM
mrjazzzzz
Jul 7, 2019 03:52 PM
Philip13
Apr 26, 2014 03:49 AM
