E type ( XK-E ) 1961 - 1975
-9 High Compression '63 XKE 3.8
Old Aug 24, 2018 | 10:35 PM
GusRiley's Avatar
Default -9 High Compression '63 XKE 3.8
I have been led to believe that most 3.8 XKEs were -8 models. -8 referring to an 8 to 1 compression ratio. I also have learned there were -7 models, but none were sent to the US. My '63 XKE Series 1, 3.8 is a -9 (9 to 1 Compression). All the numbers match my chassis. Does anyone have any idea how special this might be if special at all?
Old Aug 24, 2018 | 11:13 PM
Doug's Avatar
First I'll disclose that I'm no authority on E-types, but......
My impression is that 9.0 compression was standard specification with the lower ratios being "at request" or for select markets. I think all USA models got the 9.0 engine until the introduction of the Series II.
Old Sep 10, 2018 | 02:30 PM
XKEsGoFast's Avatar
Thumbs up E Type Compression Ratios
My 1963 E Type coupe has its original 9:1 compression ratio engine as well. I would be interested if anyone knows how many of these were built.
Old Sep 10, 2018 | 08:17 PM
Bob_S's Avatar
99.9% of the series 1 e-types sent to the USA were 9:1 compression ratio. The 8:1 engines were mainly sent to countries with lower grade fuel. Therefore 9:1 CR is not special at all.
Old Sep 12, 2018 | 04:38 PM
Bob_S's Avatar
Actually the only difference between the 9:1 and the 7 or 8:1 compression head is the number stamped into the head, i.e. there the same head RXXXX-7,8 or 9. The compression ratio is mainly controlled by the size of the dome/crown of the pistons. You could have a head that claims to be 9:1 compression ratio but if it was rebuilt with 8:1 compression pistons then the engine is really 8:1. Except when the head is shaves then it would be somewhat higher than 8:1. Some people rebuild their engines with 8:1 CR pistons because of the lower octane that is around today.
Big Worm
Nov 20, 2009 11:12 AM
skanoski
Jun 22, 2008 09:11 AM
chicago bob
Apr 28, 2008 08:22 PM
kilo
Feb 12, 2008 09:55 AM
Feb 25, 2007 10:38 PM
