E type ( XK-E ) 1961 - 1975
E-type engine swap
Old Dec 25, 2011 | 03:29 PM
Teqsand's Avatar
Default E-type engine swap
I've got a 69 E 2+2 auto.... What engine years/cars will be a pliug and play swap?
I'd like to pick up a late model 6 cyl to drop in and drive the car while I rebuild the original motor.... I'm sure I'll have to switch the intake exhaust from my motor to the new motor.....
Old Jan 5, 2012 | 04:29 PM
andy303's Avatar
Teqsand:
In general any 4.2L will work, but some are easier than others.
Several guys on the Jag-lovers forum have said they have used engines sourced from "late" model SIII XJ6s, minus the fuel injection of course. I think you will also have to change the water pump and engine sump (oil pan), as well as the exhaust and intake manifolds. If you had a 4 speed you would also need to change the flywheel. You could convert to a manual with the engine out, or maybe use a later slush box.
The fuel injected heads have bigger valves and the block is supposed to be stronger, so there are real advantages to using a later engine. Cam and valve timing remained essentially the same, IIRC, and the SIII has a v. good electronic distributor that could be used as well.
FrickenJag
Jun 16, 2025 02:15 PM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
bdboyle
Sep 4, 2015 06:16 AM
Bowman
Sep 3, 2015 03:17 PM
