E type ( XK-E ) 1961 - 1975
E-type Front Stub Axle
Old Dec 7, 2019 | 09:54 AM
71JagXKE's Avatar
Default E-type Front Stub Axle
Any trick to pressing the stub axle out of the upright carrier?
Jim
Old Dec 7, 2019 | 03:08 PM
Fraser Mitchell's Avatar
Well, if it is similar to the stub axles I had to replace on a 1980 XJ6, then no ! What you need is a "talking" hammer. A heavy hammer will be needed of the sledge type. Ypu position the hub carrier horizantally on several blocks of wood with the wood right up to the stub axle, and of sufficient height that the stub axle can sit below and not touch the ground. Loosen off the nut and then apply suitable force using the hammer. Don't worry about saving threads as you're putting new parts back on. Mine came out quite easily. As you probably know, it sits on a taper, and these can be a real PITA to break the fit.
Of course a workshop will use a press, but for us DIYers, (as I once was), needs must as the devil drives !
Old Dec 7, 2019 | 03:34 PM
71JagXKE's Avatar
Thanks Fraser.
I am certainly a DIYer, but do have a 20 ton press in the garage.
I was looking to remove the stub axle so that the upright could be sand blasted and coated.
I may make up a threaded cover for the end instead of pressing on the nut.
Jim
Old Feb 7, 2020 | 11:59 AM
Mguar's Avatar
Originally Posted by 71JagXKE
Thanks Fraser.
Jim
my 20 ton press wouldn’t do it. Even with a big rosebud tip on my gas torch. Wound up popping it lose using a 50 ton press. When it released it sounded like a gun went off. Luckily I’d put a big block of pine under it that stuck into rather than have it fly all over.
katar83
Oct 20, 2021 09:47 PM
jag902
E type ( XK-E )
Apr 13, 2015 03:56 PM
bazanaius
Dec 7, 2014 08:11 AM
Lin
Nov 4, 2011 05:35 AM
sacrider
Apr 25, 2010 10:05 PM
