E type ( XK-E ) 1961 - 1975
E-Type Fuel, Temp, Oil, Ammeter Gauge Wiring Diagram Symbols
Old Jul 30, 2015 | 10:26 PM
CraigNelson's Avatar
Default E-Type Fuel, Temp, Oil, Ammeter Gauge Wiring Diagram Symbols
My name is Craig S. Nelson, US Navy (ret). I am currently a 5th year senior at McPherson College in Kansas and will graduate in May 2016 with a B.S. in Automotive Restoration Management and a B.S. in Automotive Restoration Technology.
I am currently interning at a shop for the summer, started last month, and must depart in early August. The goal is to finish the electrical and final assembly before I leave on a '67 E-Type Series 1.5 OTS with the 4.2L engine.
The original E-Type wiring diagram from the service manual is great and have completed about 90% of the cars wiring using this particular diagram.
HOWEVER.........
The symbol used for the 4 center gauges........ammeter, fuel, temp, and oil are all exactly the same and show the needle symbol pointing upward like the gauge was upside down. This is important to know which lead to connect certain wires to, especially for the ammeter,
My pics below are designed to ask in an illustrated way which is correct regarding gauge connections on the E-Type........."Gauge Orientation Down" or "Gauge Orientation Up"???
I can always be reached at (619) 944-8971 or nelscra@bulldog.mcpherson.edu.
Attached Thumbnails E-Type Fuel, Temp, Oil, Ammeter Gauge Wiring Diagram Symbols-gauge-orientation-down.jpg   E-Type Fuel, Temp, Oil, Ammeter Gauge Wiring Diagram Symbols-gauge-orientation-up.jpg   E-Type Fuel, Temp, Oil, Ammeter Gauge Wiring Diagram Symbols-series-1-wiring-diagram.jpg
Old Jul 31, 2015 | 12:22 AM
bkeats's Avatar
You will find an unmistakeable connector on the gauge that will be for ground, either Positive or Negative Earth (in your case it should be Negative Earth). You can confirm this with a multi-meter set to test for continuance and test for continuance between the suspected Earth connector of the gauge and the housing of the gauge. The wire from the various Sender Units, such as Oil Pressure, Water Temp etc., will connect to the Earth connector of the gauge. The other connector will connect to the wire that comes from the Voltage Regulator for the gauges. Accordingly, when trouble shooting gauge or sender problems, the gauge can be eliminated by shorting the wire that connects the Earth connector of the gauge to the sender, straight to Earth. If the gauge is OK and there are no breaks in either wire, then the gauge should peg out to its max reading.
Regards,
Brent
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
giandanielxk8
Sep 6, 2015 07:21 PM
AL NZ
Sep 4, 2015 08:39 PM
Bcrary3
Sep 3, 2015 03:48 PM
