E type ( XK-E ) 1961 - 1975
fan belt rubbing on water pump hose
Old Feb 29, 2020 | 12:38 PM
racerxf12004's Avatar
Default fan belt rubbing on water pump hose
68 XKE. Fan belt is rubbing on the water pump hose. Makes a squealing sound that has been getting louder recently. The fan belt could be old. I'm thinking it could have stretched? Are the fan belts on your guys xke's this close?
Old Feb 29, 2020 | 04:30 PM
David84XJ6's Avatar
From memory... if you loosen alternator pivot bolts and hold off-bracket, then pull alternator as far as possible from center of engine, the belt will tighten and pull the idler pulley away from coolant hose, Then tighten alternator hold-off bracket and alternator pivot thru bolt.
Old Feb 29, 2020 | 05:18 PM
That was the problem!.I had the alternator loose a few weeks ago and didn't put it back in the right position. Thanks david84xj6.
mickvic
XJ40 ( XJ81 )
Apr 28, 2017 10:58 PM
orangeblossom
Jan 8, 2017 11:12 AM
MalnFaye
Sep 1, 2016 09:06 AM
scrible
Dec 25, 2012 02:43 PM
Virgilson
Nov 7, 2011 12:42 PM
