E type ( XK-E ) 1961 - 1975
Front brakes locked up 68 E-Type
Old May 22, 2018 | 05:30 PM
Joe Weaver's Avatar
Default Front brakes locked up 68 E-Type
Have made the mistake of letting my 68 Etype sit up for 5 years. Installed new battery today, along with new fan belt, and muffler mount. Thought I was ready to roll. It fired but when I engaged the clutch the front brakes were locked up solid. I sprayed the rotors down with WD-40 trying to get things to free up. They did some but still pinching pretty hard. Thinking its the pistons in the rotors frozen and wondering before I start taking things apart if they could possible be freed up or rebuilt or should I replace. I know I'm probably asking questions ahead of time but curious if anyone else has had this occur and what their results ended up being?
Old May 22, 2018 | 06:31 PM
alfred's Avatar
I had something similar happening to my 68 2+2, but I was able to drive it for a short distance until smoke started coming from the brakes. I Rebuilt the callipers, honed the rotors, and replaced the flex lines with SS braided to fix the issue. Hope that helps.
Old May 22, 2018 | 06:48 PM
Joe Weaver's Avatar
Thanks a bunch. Sounds like that is where I am headed.
Old May 23, 2018 | 05:24 AM
George Camp's Avatar
Joe you could pull the pads and see if the pistons will retract.
Old Jun 6, 2018 | 04:45 PM
edstoll11's Avatar
Hi. Can someone tell me how to install the CHOKE Cable in a 65 jag roadster? I took the cable out long ago but I have tried over and over again to install it but haven't found the
right way to do it. Could someone take pity on an old jaguar nut and assist me in doing
this right?
Old Jun 7, 2018 | 06:42 AM
alfred's Avatar
In a perfect world the top of the dash can be removed with a few screws. That will allow you access to re-connect the choke cable from above. In my case the dash was glued in so I cut a small hole in the left side of the glove box to access the choke mechanism. Hope you have small fingers
mikchek
May 8, 2019 11:38 AM
lilydog
Feb 22, 2018 02:24 PM
nlmay
Aug 10, 2016 08:00 PM
edtexas
Aug 13, 2015 09:22 AM
bendy
Sep 3, 2014 08:56 AM
