E type ( XK-E ) 1961 - 1975
Mystery noise
Old Feb 21, 2020 | 08:39 PM
Tappetman's Avatar
Default Mystery noise
Trying to locate the source of a particularly awful " metal on rotating metal " noise that occurs when i'm steering left around a corner in my '66 xke coupe.
Hard to be precise but the noise appears to be coming from the front of the car.
I have had a good look around under the bonnet, front wheels, radiator fan, all seem ok.
This first happened when i was cornering hard with a heavy passenger ( sorry Fred ) and since then has occurred with less and less cornering speed and no passenger.
Would be grateful for any ideas ..
Old Feb 22, 2020 | 12:55 PM
billb44's Avatar
I had a similar experience and the surprising cause was just a buildup of junk between the inside rotor surface and the dust guard. When cornering, it hit the brake pad and got it vibrating with a metallic sound. Next time you hear it give the brake a tap.
Old Feb 22, 2020 | 02:13 PM
Fraser Mitchell's Avatar
Tappetman, do you realise you have posted your thread twice ? Might be best to ask a moderator to combine the two.
Old Feb 23, 2020 | 08:15 PM
Tappetman's Avatar
Thanks Bill, really appreciate your reply, will take the wheel off and take a look.
Old Feb 23, 2020 | 08:18 PM
Tappetman's Avatar
Yes .. sorry Fraser .. bit rusty on how to post.
Not sure how to get to a moderator to fix the double post. ?
Tappetman
E type ( XK-E )
Feb 28, 2020 02:10 PM
omgimali
Apr 26, 2017 12:43 AM
AfricanJag
Feb 18, 2015 01:30 AM
shotime92
Jul 30, 2013 10:10 PM
