E type ( XK-E ) 1961 - 1975
Over My Head on Electrical
Old Nov 18, 2023 | 04:01 PM
jjmdj725's Avatar
Default Over My Head on Electrical
'71 S2 OTS - installed a new alternator and in hooking up the harness .... now when I connect the battery ... the starter engages even with the key off?? Don't have a LATE S2 electrical schematic?
Old Nov 18, 2023 | 10:27 PM
mxfrank's Avatar
ID you install a stock alternator, or did mod the harness? There should be nothing that ties the alternator harness directly to the starter.
You can find an S2 diagram on my website. Since you have the later car, you will have the ballast circuit:
https://www.coolcatcorp.com/faqs/XKE...s_2_Wiring.pdf
Old Nov 19, 2023 | 04:17 PM
jjmdj725's Avatar
mxfrank, Thanks for the reply. I replaced the Starter Solenoid at the same time ... was careful when I changed all five wires ... but ... ?? Could two of the wires be backwards? I also pulled the Brown wire of the ignition ... put it back on where it looked like (scratches/shiney) it came off of. Afraid to just start switching wires in case it melts something.
Old Nov 20, 2023 | 08:59 PM
billb44's Avatar
You have a brown wire bringing 12v to the ignition switch. You have another wire from the switch (start terminal) to the solenoid. Reverse those 2 and it will act as you described. Check carefully.
nunger1330
XJ40 ( XJ81 )
Dec 23, 2019 06:27 PM
Len Apcar
Jan 18, 2017 01:17 PM
Dixter
Aug 5, 2016 03:05 AM
tpwild
May 22, 2012 12:55 AM
optras
Sep 13, 2011 11:50 AM
