E type ( XK-E ) 1961 - 1975
Series l Steering Wheel Removal?
Old Aug 8, 2016 | 02:25 PM
khwilm's Avatar
Default Series l Steering Wheel Removal?
I am trying to remove the steering wheel on my 63 E-Type, I removed the center horn button and the three set/grub screws on the steering wheel base. I thought the black center disc would then pop out. It did not and now spins freely. I don't want to pry it out for fear of breaking it. What am I missing?
Thanks - Kevin
Old Aug 9, 2016 | 03:24 PM
Mr. Barry's Avatar
It's been many years since I had a Series 1 car. There should be a lock (jam) nut followed by the main steering nut...Just remove them, and the wheel will come off the splines ....You will have to wiggle the wheel, as you pull.....
Edward
Old Aug 10, 2016 | 09:51 AM
khwilm's Avatar
Thanks for the reply. I am stuck with trying to remove the plastic disc shown in the photo to get to the nuts you are referring to. I was able to remove one of the three grub screws from the back of the steering wheel base. I had to drill out the other two as I could not turn either of them with a small screw driver. After drilling the other two screws out, the black disc spins freely but will not pop out as I expected it would. Thanks - Kevin
Old Aug 10, 2016 | 11:08 AM
Jagrick's Avatar
there are 3 grub screww that need to be removed all the way. Then the center piece comes out.
Old Aug 10, 2016 | 11:09 AM
Jagrick's Avatar
Not sure how you got the center of the horn out that usually comes out as a unit??
Old Aug 10, 2016 | 11:12 AM
Jagrick's Avatar
wa3ra
Apr 12, 2016 07:40 PM
hisport
Apr 3, 2016 07:34 PM
IronCobra
May 21, 2013 01:44 PM
May 26, 2007 03:41 AM
vaccaro81
Feb 3, 2007 12:16 PM
