E type ( XK-E ) 1961 - 1975
Sticking throttle 68 S1.5 automatic tranny
Old Dec 26, 2020 | 06:45 PM
DeusExMaxima's Avatar
Default Sticking throttle 68 S1.5 automatic tranny
My 68 S1.5 automatic tranny equipped E has always seemed to have a sticky throttle. I think the kickdown cable may have something to do with it, although it is new. Problem gets worse when engine is hotter. I added a return spring with little improcement. Is there a cable conversion for that improvement. I know the Lotus Elan has similar twin ZS carbs with a cable. Help please.
Old Dec 27, 2020 | 11:40 AM
alfred's Avatar
Originally Posted by DeusExMaxima
My 68 S1.5 automatic tranby equipped E has always seemed to have a sticky throttle. I think the kickdown cable may have something to do with it, although it is new. Problem gets worse when engine is hotter. I added a return spring with little improcement. Is there a cable conversion for that improvement. I know the Lotus Elan has similar twin ZS carbs with a cable. Help please.
This is a common issue with E-types. Mine was doing the same thing (68 2+2) . Look carefully at the throttle linkage where it is closest to the engine frame while someone pushes down the throttle petal. Likely some rubbing/sticking there as this happens when the engine mounts pancake over time. A temp fix is to loosen the mounts a bit, raise the engine from below using a wide plank under the oil pan, and slip a thick washer or shim over the engine mounts. Use horseshoe shaped shims, or cut a slot into a washer. Or order new mounts and replace them to get more clearance between throttle linkage and engine frame.
Old Dec 27, 2020 | 11:48 AM
I replaced the motor mounts with urethane mounts. It raised the motor quite a bit. The kickdown cable seems to be the sticking point. It's also odd that when engine is cold, it works fine. But when it is hot, it gets sticky.
Old Dec 27, 2020 | 05:14 PM
I installed a firm return spring. I feel like it's more of a bandaid rather than solving the problem.
Daim
Oct 9, 2017 11:09 PM
john_cook12
Jun 20, 2016 08:13 AM
anziobridgehead
Aug 1, 2015 09:00 PM
magnum454
May 7, 2014 11:38 AM
SteveM
Sep 11, 2012 03:23 PM
