E type ( XK-E ) 1961 - 1975
Tachometer issues
Old Jul 15, 2021 | 04:29 PM
Gjbacci's Avatar
Default Tachometer issues
Just sorting out a 1969 2+2. The tachometer works fine at low RPM,s. However it won’t go any higher than 2300 RPM. The car has a Petronix module instead of points.
any ideas where to start.
Old Jul 16, 2021 | 06:43 AM
Coventry Foundation's Avatar
Most likely the Tach needs a rebuild. Common problem for that tach at this age. Nissonger does a fine job.
Old Jul 16, 2021 | 06:47 AM
dibbyandco's Avatar
The Petronix shouldn't have any affect. Some cars have issues with the Tach when they fit a 123 tune dizzie. Could be the Tach or the feed to the tach
Old Jul 25, 2021 | 08:02 PM
mxfrank's Avatar
I guess nobody understands how this system works. The ignition system matters, and the tachnometer needs to be adjusted. On a '69, it's an easy task, because the tachometer can be adjusted without opening the case. There is a trimmer that can be accessed by an opening on the back of the case. It will covered by a rubber plug or if it's been adjusted before, by a piece of tape. Just pry it open and you will be able to reach the trimmer with an insulated screwdriver. Start the car and adjust to match any good shop tach.
Tahoe Dave
Mar 6, 2026 12:22 PM
Tony Qartveli
Dec 8, 2022 06:40 AM
Speedmaster
Jun 10, 2021 10:32 AM
Fred2
Dec 14, 2014 03:30 AM
Filos Hippos
Feb 18, 2010 06:21 AM
