E type ( XK-E ) 1961 - 1975
What are these?
Old Nov 27, 2015 | 03:36 PM
1970WillowGreen's Avatar
Default What are these?
My dad and I are restoring his 1970 Jaguar E-Type and we're replacing all the hoses and we don't know what these hoses are for. They aren't the heater core hoses. Can anyone tell us?
Thank
Old Nov 27, 2015 | 10:11 PM
vrracing's Avatar
Yes they are. They go thru pipes behind the firewall over to the heater. The pipes are famous for rusting out and are incredibly difficult to replace.
Here is a picture from SNG Barrett's catalog...
SNG Barratt - The Ultimate Jaguar Parts Specialist
Jim
Old Nov 27, 2015 | 10:21 PM
Thanks for the info, we broke one of the pipes coming out of the dash taking off the hose but it might still work.
Old Nov 28, 2015 | 03:36 PM
What is this and why is it clogged?
Old Nov 28, 2015 | 03:55 PM
What the hell is this too? Lol it's in the air filter mount for the carbs. It's not hooked up to anything and there's some vacuum thing on the outside of the airfilter cover that wasn't hooked up either
Old Nov 28, 2015 | 07:46 PM
vrracing's Avatar
You probably want to pick up the Bentley's manual or even better the SII book from XKEBooks.com. The stuff you're looking at is pollution controls and they were pretty crude and improvised at that time. Here is a doc from Jaguar describing the emissions for 1970.
http://www.xkebooks.com/images/1970%20Specs.PDF
Old Nov 29, 2015 | 12:21 AM
Thank you. Did you ever put the factory Air back on your XKE? My dad pulled it back in the day and we still have all the parts for ours.
Old Nov 29, 2015 | 11:11 AM
Mr. Barry's Avatar
My advice is if you don't live in a hot climate, discard it...Car will run better(and look better), without it...It was not a factory option, but dealer added, and frequently made the car overheat in traffic...You would want to return the alternator to its factory-correct position, and discard that huge alt/a/c bracket... You will also simplify the wiring and eliminate a bunch of ugly extra hoses. Just my 2 cents.
Edward
Old Nov 29, 2015 | 12:02 PM
vrracing's Avatar
We live in Austin so the a/c will be going back on. But we're quite a ways from there.
If you're in the central valley, then you'll probably want the a/c. If you're high up in the Sierras probably not and the thinner air will make it harder for the cooling system.
If you do install the a/c, keep in mind that radiator technology has advanced dramatically since the 60s, so you can get a much more efficient radiator. And since you have an S2, you don't have to mindlessly adhere to originality like you would with an S1.
A/C technology has also advanced dramatically; cooling much better while putting less stress on the engine. There is a company in Dallas that can help upgrade the a/c before you put it back in.
Jaguar XKE Full and A/C Kits | RetroAir, Inc.
Old Nov 29, 2015 | 10:21 PM
Dleit53's Avatar
I am pretty sure this is the device that controls the hot or cold air going into the air cleaner. It should have 2 vacuum nipples, one goes to manifold and the other to the vacuum actuator on the air cleaner.
Old Nov 30, 2015 | 12:12 AM
No vac lines connected to any of those things you mentioned. Would the car run better with them connected?
Old Dec 7, 2015 | 10:28 PM
Dleit53's Avatar
Maybe when it is cold out, probably not in warmer weather. If below about 50F, and damp, you might get carburetor icing without it.
Old Dec 8, 2015 | 03:27 AM
vrracing's Avatar
That's for emissions control and its function is described on the fourth page of the PDF from xkebooks I linked for you in post 6.
Old Dec 9, 2015 | 12:29 AM
yeah i saw, thanks!
ionixxx
Sep 18, 2023 04:33 PM
powerhouse
Dec 3, 2015 01:36 PM
LnrB
Nov 28, 2015 05:31 AM
carid
VENDOR 'For Sale' Classifieds
Nov 27, 2015 07:17 AM
marmar1305
Nov 21, 2015 05:55 PM
