E type ( XK-E ) 1961 - 1975
xke v-12 running too rich on one carb
Old Apr 21, 2023 | 02:51 PM
egold56's Avatar
I am trying to resolve the same problem. I am looking at the bypass valve, the temperature compensator or the starter box. if the float settings are good then unless someone has messed with the jet height ( which is not easy to do) you may need a new needle. Ia the choke on the front right. i think it is. That can be installed 180 degrees out and that could cause the problem. If no resolution send that carb to Joe Curto. He is teh Zenith Stromberg guru.
EricStone
Oct 31, 2021 12:12 PM
brinny
Aug 17, 2021 06:38 PM
knares
Aug 14, 2018 08:48 AM
blackdoublesix
Jan 4, 2016 05:26 AM
christophe37
E type ( XK-E )
Mar 3, 2015 01:35 PM
