Exterior Talk about your rims, bodykits, and other exterior mods here.
loose jaguar emblem 2003 xjr
Old Feb 3, 2010 | 03:34 PM
stuntmanmike's Avatar
Default loose jaguar emblem 2003 xjr
Hi,
The jaguar emblem on the passenger side fender of my 03 xjr is loose. Any suggestions on how that might be secured?
Old Feb 17, 2010 | 03:40 AM
viscoussquirrel's Avatar
While I haven't the slightest as to how yours is attached, there's usually methods, screws and glue. see if it has nuts on the back that can be tightened. If that doesn't work, some 3m tape or jb-weld may be in order.
Old Feb 17, 2010 | 06:43 PM
hlgeorge's Avatar
Most badges and emblems are attached with the 3M double sided molding tape. If it is loose, I would just pull it off and get some 3M molding tape at any auto parts store and replace it. Be sure to clean both surfaces thoroughly B4 replacing the tape.
BrentGardner
29
Dec 16, 2024 12:13 AM
reedmtn
Aug 31, 2015 12:48 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
Zues
Aug 27, 2015 12:02 AM
Terrance Williams
Aug 26, 2015 11:50 AM
