F-Pace (X761) / C-X17 2016 - Onwards
Dreaded P2187 2189 codes
Old Mar 15, 2026 | 11:56 AM
sboone1074's Avatar
Default Dreaded P2187 2189 codes
Just bought a 2017 F Pace S and two days later these codes popped up 🤬
Old Mar 15, 2026 | 05:33 PM
cstall's Avatar
System Too Lean at Idle (Bank 1)
System Too Lean at Idle (Bank 2)
Vaccuum leak, MAF sensor fault, PCV fault, symposer leak - basically, air is getting in that isn't supposed to be getting in.
Old Mar 15, 2026 | 08:08 PM
BritCars's Avatar
Did it come with any initial warranty eg 30 day?
Old Mar 16, 2026 | 07:19 AM
sboone1074's Avatar
No warranty, but the dealer agreed to check out the car today. Not sure what that means but we will see.
Old Mar 16, 2026 | 07:18 PM
sboone1074's Avatar
Dropped it off at the dealership, they are going to cover the cost of whatever the fix action is
Old Mar 16, 2026 | 10:23 PM
MSCA's Avatar
That’s great! That dealer’s a keeper. You have an opportunity to build a relationship with their service folks - a relationship with the foreman / lead tech is priceless.
Old Mar 17, 2026 | 02:31 AM
austinjag's Avatar
Please fill us in on the resulting issue and fix. I’m currently dealing with the same thing, but only show the p2187 code. I can’t seem to find any vacuum leak though.
Old Mar 17, 2026 | 02:41 PM
sboone1074's Avatar
I’ll definitely let you all know the outcome.
Old Mar 18, 2026 | 08:34 AM
RoverJoe's Avatar
Community Influencer
"dreaded" codes on a 10 year old car, don't be dramatic. Just get it fixed.
I have started to see some V6 air leaks around the rear main seal, which is odd. But usually it's the more common places at that age, vacuum leaks, valve covers, etc. Any JLR dealer should have no issue fixing it.
Bigbuck1991
Apr 15, 2025 09:37 PM
2003JagStr
Nov 8, 2022 02:04 AM
93xjs6cyl
Oct 4, 2022 06:32 PM
WaterDragon
Oct 11, 2012 01:55 PM
The World Tour
Jan 9, 2012 01:35 PM
