F-Pace (X761) / C-X17 2016 - Onwards
F-Pace - radiator pack replacement
Old Aug 17, 2022 | 05:08 AM
Nisignco's Avatar
Default F-Pace - radiator pack replacement
hello everyone nice to be on the forum for the first time, i have a 2016 f pace that had some damage to the radiator pack which i have now replaced. can anyone tell me what would be the total amount off water & coolant it should hold to refill the complete pack?. i have put in around 3-4 ltrs. but not sure if it is full through the entire system it didn't seem to take very much . how can i check this ? and what do i need to do to be sure?
many thanks for any advice in advance
Old Aug 17, 2022 | 08:15 AM
Welcome to the forums Nisignco,
Capacity depends on the engine fitted to your vehicle.
COOLING SYSTEM CAPACITY
3.0L Petrol - 7.7 litres
2.0L Petrol - 9.05 litres
3.0L Diesel - 9.2 litres
2.0L Diesel - 7.7 litres
SPECIFICATION
Mixture of 50% water and 50% coolant meeting JLR specification STJLR.651.5003
When I've had the cooling system 'open' to replace a hose, water pump etc:
1. slowly fill to the MAX mark on the reservoir
2. refit the reservoir cap
3. run the engine up to temperature
4. check for leaks
5. allow the engine to cool completely
6. check the level in the reservoir
7. top up if necessary
Enjoy the forums.
Old Aug 17, 2022 | 10:52 AM
Nisignco's Avatar
Thanks very much for the advice i will do as you advice
cheers j
Old Sep 12, 2023 | 01:09 PM
Stillstunner's Avatar
Hi mate I’m trying to figure out how to remove my rad pack. I want to figure out which bolts to remove to make it easiest. Any help appreciated
mhamilton
Aug 29, 2022 02:40 PM
BoomBoomZ31
Apr 6, 2022 07:20 PM
andyXJR
Sep 29, 2015 04:29 PM
Lcgi
Oct 5, 2014 07:01 AM
joe66
Mar 20, 2013 07:22 AM
