F-Pace (X761) / C-X17 2016 - Onwards
F pace SVR winter rims
Old Oct 17, 2019 | 05:34 PM
Mulmur's Avatar
Default F pace SVR winter rims
I have had some difficulty finding alloy winter wheels for my SVR... as 21" snows are a bit rare, I'm trying to find 20" rims that will fit over front calipers.
So far the tire dealer has tried a well known brand FC and no luck as even at a 45 offset, the spokes rub the caliper.
Lawrence
Old Nov 9, 2019 | 10:19 AM
Mulmur's Avatar
Lawrence
I'm told that Speedline Wheels have 20" that fit.. awaiting confirmation.
Lawrence
Old Nov 13, 2019 | 04:13 PM
leadfoot4's Avatar
Have you looked into 'Braelin' wheels?
Old Nov 13, 2019 | 04:18 PM
Mulmur's Avatar
No, I have not... the Speedline do fit the Fpace SVR fronts as per a local dealer that just tried them out for fit yesterday. I've already bought these and will be mounting Nokia snows..
Lawrence
Old Dec 2, 2019 | 05:38 PM
Mulmur's Avatar
Lawrence
Finally, I mounted the new wheels/Nokian winters and all is good. The other wheels mentioned above do look good in pictures though, but as mentioned I already bought the speedlines.
Larry
Old May 12, 2020 | 12:10 AM
KirklandWa's Avatar
Which Speedline rims did you get?
Old May 13, 2020 | 08:46 AM
Mulmur's Avatar
Speedline wheel.. detail to follow once I find the order sheet. Lawrence
Old May 14, 2020 | 04:37 PM
Mulmur's Avatar
On the bill of sale, it refers to 'Marmora', which I assume is the style of Speedline wheel... if that doesn't work, I can likely get a model # from the dealer.
Lawrence
Old Nov 5, 2021 | 07:57 PM
Jpknupp's Avatar
Just ordered a new 2021 F Pace SVR. I live in Evergreen, CO, at 8000’. We have to run dedicated snow wheels / tires on all our cars, and most we run studded (Nokian Hakka 8 or 9). Do you happen to know exactly which wheel bolt spacing and offset will work? I found the Speedline Marmora 20”. 5-bolt. But, there are a few sizes:
5 x 108
5 x 120
Both appear to be 40mm offset. I’d prefer to run the same offset in front and back for my winter set, and not run staggered tires. Doing this on my wife’s Levante GTS that has a staggered summer set up.
Thank you in advance!
BruceTheQuail
Mar 12, 2020 06:21 PM
Peter O.
Sep 30, 2019 02:13 PM
FType17
Jan 25, 2018 01:52 PM
a8silver
Oct 15, 2017 12:32 PM
BruceTheQuail
Sep 22, 2016 07:13 PM
