F-Pace (X761) / C-X17 2016 - Onwards
Fob Battery
Old Aug 8, 2021 | 10:58 PM
Madrona1's Avatar
Default Fob Battery
The Fob battery warning light came on the battery was low. Replaced it with the 2032 lithium battery no problem. Now the car will unlock and lock at the handle, start & stop but the remote will not work to unlock at a distance. I'm talking about standing in the garage?? Anyone have an issue like this?
Old Aug 11, 2021 | 08:13 AM
gearFX's Avatar
Did you ever find a solution?
Old Aug 11, 2021 | 10:41 AM
Madrona1's Avatar
Problem solved, took out a lithium battery and replaced it with a conventional one and everything works fine. Still seems strange.
Old Aug 11, 2021 | 11:31 AM
2018XF25T's Avatar
Avoid buying coin batteries that are Made in China even though it's a famous name brand. Coin batteries that are Made in USA, Japan & Switzerland are the best
Old Sep 13, 2021 | 02:03 PM
Dave R's Avatar
Handy to know, did you have to re sync or prog fob or is it automatically connected after changing the battery?
Old Sep 14, 2021 | 03:50 PM
2018XF25T's Avatar
I opened my XF Key Fob case to see what I bought this time for a coin battery,inside is,a Maxell CR2032 H Made in Japan. I didn't have a problem, once coin battery is installed, the FOB just operated as is once I clicked on the buttons. I also, changed the Key Fob casing as original silicon skin starts to separate, very annoying at times when I used it. Now it looks & feels new once again
Also, watch out for fake coin batteries.
https://shopmaxell.com.au/all-articl...xell-products/
https://www.microbattery.com/counter...coin-batteries
khsjsilver
Jul 27, 2021 09:02 AM
CzechFrank
Jun 5, 2021 06:25 AM
Silver cat
Mar 19, 2018 11:17 AM
Mike Graham
Nov 1, 2013 07:10 AM
chazaroo
Feb 24, 2013 02:21 PM
