F-Pace (X761) / C-X17 2016 - Onwards
SVR wheel width front and rear
Old Feb 13, 2021 | 07:04 PM
LTHLVPR's Avatar
Default SVR wheel width front and rear
I’ve seen posts but no real confirmation of the stock wheel widths for the SVR.
Seen people guess at 10” for the rears but I’m not convinced as that is suboptimal for a 295 width tire that comes stock. I’m thinking it’s either 10.5” or 11”.
Anyone able to confirm?
Old Feb 14, 2021 | 07:50 PM
StuG's Avatar
Okay, I do not own an SVR. I cannot find any definitive info on wheel width. All four wheels on my 2017 are 9". Sometimes the wheel size is stamped on the inside of the rim. You will have to remove a wheel in order to look for it. Worst case scenario is you take the wheel into a tyre shop and have them measure the width if you cannot do it yourself. I would be surprised if the wheels are 10.5" or 11".
Old Feb 15, 2021 | 01:06 AM
JacksonvilleJag's Avatar
The rear wheels are 10", fronts are 9".
Old Feb 20, 2021 | 01:48 PM
leadfoot4's Avatar
You ought to be able to slip a ruler or tape measure through the spokes of the wheel, and align the edge of the ruler with the edge of the "inner barrel" of the wheel, then read the numbers at the outer edge of the barrel. Keep in mind, you do NOT include the beads, when measuring rim width. If you're not sure if you can reach in, and set your ruler at the edge of the barrel, but can accurately gauge the outermost edge of the wheel, them measure from there, do the same on the outside of the wheel, and subtract 1 inch.
Old Feb 22, 2021 | 06:39 AM
Rummy636's Avatar
Its built in on the inside of the rim spokes. Little mirror and flashlight will tell you the size.
Old Feb 22, 2021 | 07:15 AM
Since y'all don't want to believe nobody. Click here https://www.jaguarforums.com/forum/vindecoder.php and enter an SVR VIN. I did mine and it came up with these results.
Old Feb 22, 2021 | 10:33 AM
Rummy636's Avatar
Dont get all irritated. Some people are just educating others how to find the size on almost any alloy wheel by checking with a mirror and flashlight
Old Feb 24, 2021 | 03:38 AM
Oh sweetie, nobody is irritated.
mecheng1
Mar 20, 2021 02:48 AM
LockNumber25
May 14, 2020 06:57 PM
Peter O.
Sep 30, 2019 02:13 PM
Tahoe Dave
Aug 17, 2017 01:54 PM
BruceTheQuail
Sep 22, 2016 07:13 PM
