F-Pace (X761) / C-X17 2016 - Onwards
Too much pressure (inward) in the expansion tank
Old Aug 25, 2024 | 05:00 PM
ychandra's Avatar
Default Too much pressure (inward) in the expansion tank
Hi All,
I'm new to the Jag world, I recently bought a jag f-Pace with 73,000 miles on it, the main issue which I'm facing is the following and would highly apprecaition the advice here:
1. Even after the engine cools down for a day/two, there is excess inward pressure built up in the colant expansion tank (pulling the coolant level way below the min mark, infact it was towards lower end of the tank)
-> Once I open the expantion tank cap, all the pressure is released and the coolant level comes back to Normal, between min and max guage.
-> While running, at times I see engine coolent level low (read dashboard error) as well, once the pressure cap is release off some pressure, it goes back to normal
2. Another observation, is that every day I start the engine for the first time, the engine has starting issues, lots of missfire and the engine cranks a long time (5 to 10 seconds) before it could start, after which I do not see any miss fire or issues while the engine is running, everything is quiet smooth.
Other Observations:
1. Engine Coolant Temperature is around 88 to 105 degree celcius - duning running conditions.
2. Not seeing any white smoke in the exhaust, nor frothy coolant.
3. No coolant leakes observed, once the cap is opened the coolant level comes back to normal.
Note:
I have already replaced the coolant cap to 200kpa
Old Aug 25, 2024 | 05:02 PM
ychandra's Avatar
Car Make and Model:
Year: 2017
Model: F-Pace, Prestige 35 t
Others: Gas engine, with v6
Old Aug 27, 2024 | 01:04 PM
Pepix's Avatar
Try parking the car on a small incline and run the car until it reaches around 100 degrees C (turn it off before overflowing), with the reservoir cap open and HVAC temp. set on HI. During this also raising the engine speed to 2000 RPM every 2 minutes for 20 seconds helps to push the air out. My bet is that You have some air in the system left. Were there some cooling system jobs done by the previous owner?
Old Aug 27, 2024 | 01:23 PM
ychandra's Avatar
I not sure about the previous owner, but I did a full coolant bleed and did what you said that did the magic. Thank You sir.
joekluger
Jan 19, 2024 07:34 PM
Burl
Jul 27, 2019 10:34 AM
XJ8Lou
Oct 13, 2017 05:29 PM
King Charles
Jul 18, 2017 05:37 AM
kchirume
Nov 4, 2010 07:06 AM
