F-Pace (X761) / C-X17 2016 - Onwards
Urgent I need help with a 2018 F-Pace (X761)
Old Apr 1, 2024 | 02:40 PM
Fire123's Avatar
Default Urgent I need help with a 2018 F-Pace (X761)
I have all the trouble codes and the problem is randomly it will say “gearbox fault detected” and the gear selector will blink in Drive gear and won’t move. But also now it won’t indicate it’s in park on the selector.
the codes are:
P0850-29
Park/neutral switch input circuit - Signal invalid
Permanent
P07B3-11
Transmission park position sensor A - circuit low - Circuit Permanent short to ground
P07B9-11
Transmission park position sensor B - circuit low - Circuit short to ground
Permanent
P1707-77
Transfer case gear N or gear N/P indication circuit - Commanded position not reachable
Permanent
P1707-72
Transfer case gear N or gear N/P indication circuit - Actuator stuck open
P1707-94
Transfer case gear N or gear N/P indication circuit - Unexpected operation
Permanent
Am I having a problem with a gear selector or the transmission range sensor or something else?
Old Apr 2, 2024 | 03:00 AM
Welcome to the forums Fire123,
Have you fully charged the vehicle battery then cleared the codes and, if so, did the same subset return?
Jeff Wallman
Oct 9, 2023 08:09 AM
PVSJAG
Jun 20, 2023 08:06 AM
RA110623
Jan 19, 2021 08:13 AM
Rogelio Serrano
Dec 4, 2016 10:50 AM
X Ray
Nov 16, 2013 11:27 AM
