105 octane gas ....
Old Jun 26, 2017 | 06:47 PM
Ubad2's Avatar
Banned
Default 105 octane gas ....
Hi guys,
By chance i came across a business that sells home heating fuel and different octane level gasoline. I'm under the belief that race fuel is of no benefit to our car but i thought I'd ask all of you, because someone will give me a definitive answer whether or not 105 octane gas will make more power in the V8 motor. My guess is no, it can not increase the HP because of the engine software parameters being set for standard gas. Your thoughts please. Thanks
Old Jun 26, 2017 | 07:10 PM
Unhingd's Avatar
Anything more than 93 is a waste of money, and based on the distillation range may actually decrease power. If the engine were running 14:1 compression, of course you would benefit from 105 octane, but the AJ133 engine is only running a 9.5:1 compression ratio.
Old Jun 26, 2017 | 07:59 PM
Ubad2's Avatar
Banned
Default Wow ...
That is truly a gear head reply and i thank you Sir. I wish i had such knowledge with cars.
Old Jun 26, 2017 | 09:04 PM
Bushwhacker's Avatar
Octane us raised by additives to the gasoline which inhibits ignition so you do not get pre-ignition prior to the spark (ie, pinging).
In order to delay ignition some of the energy producing gasoline is replaced by these inhibitors.
Hence, the higher the octane, the lower the energy content of the gasoline.
To maximize energy you should run the lowest octane gas your car will run without pinging.
This assumes your car is not programmed to compensate for lower octane gasoline. My understanding is the 2.0 turbo charged engine in the Pontiac Solstice GXP/Saturn Sky Redline will run any octane gasoline but is programmed to alter the timing to lower the compression ratio if regular gasoline is used, to prevent pinging.
Old Jun 27, 2017 | 10:24 AM
Dogbreath!'s Avatar
It may (probably) retards timing, but it doesn't do squat to compression.
Old Jun 27, 2017 | 10:58 AM
Mikey's Avatar
Octane rating of gasoline has nothing to do with 'pre-ignition' or 'pinging', it's 'detonation' or 'knock'. The two terms are not interchangeable, nor are the different phenomena in any way similar.
Pre-ignition is premature but otherwise normal 'burning' of the fuel, detonation is 'uncontrolled explosion'. Detonation occurs after normal ignition of the fuel, not before.
The various components and additives in gasoline act to raise or lower the tendency to detonate. The actual variation in energy content (BTUs) from the lowest to highest octane fuel is insignificant.
Jaguar designed and certified the engines in N.Am. spec cars to produce full rated power on 91AKI fuel. Euro cars are spec'd to produce full rated power on 95RON fuel.
Using fuel lower than recommended may (or may not) result in lower power output and increased consumption. Such effects would be the result of the lower octane fuel not having the capability of withstanding the tendency to detonate. The engine knock sensor(s) would detect the event and retard the ignition timing until such time as the detonation is under control. Retarded ignition timing causes the engine to reduce it's combustion efficiency, hence reduced power and increased fuel consumption.
As to whether using higher octane fuel than recommended would increase power or not is possible, but unlikely. Several things would need to occur but primarily:
Is the engine subject to detonation on it's current rated fuel? If no, then there's no detonation to eliminate and no benefits to be had. If yes, will the engine software allow the ignition timing to be advanced?
If no, then using higher octane fuel is of no benefit. If yes, does the current ignition advance curve programming represent the optimum for power output and efficiency?
If yes, then more ignition advance would be counterproductive. If no, then more ignition advance would produce more power and reduce consumption.
Research on the 4.2L V8s used in the predecessors to the F-type indicated that using anything higher than 91AKI/95RON was of no benefit. As to whether the same results would apply to an F-type, I have no idea.
The last time I looked at pump prices for 105 AKI fuel, they were around $8-10 USD per gallon. Anybody willing to experiment?
Old Jun 27, 2017 | 10:59 AM
Mikey's Avatar
Correct.
Old Jun 27, 2017 | 11:48 AM
Unhingd's Avatar
Not quite true. It depends entirely on what blend components are used to raise the octane. Gasoline containing ethanol, for example, can reduce the thermal content by as much as 3%, and if the distillation range of all the blend components is out of balance as a result of top loading with the high octane components, the combustion will perform unequally over the entirety of the rpm range, sacrificing power.
Old Jun 27, 2017 | 11:59 AM
Mikey's Avatar
True enough, but that's bringing in another variable other than just octane rating. Using your example, it can be said that 87AKI E10 gas has 3% less energy content than 91AKI pure gas or conversly that 91AKI E10 has 3% less energy than 87AKI pure gas.
I chose to compare apples to apples by presuming that two fuels were otherwise identical other than octane rating.
Old Jun 27, 2017 | 03:17 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
Using 105 "may" "possibly" burn valves if the conditions exist to do it....btdt...looong ago...
Old Jun 27, 2017 | 03:47 PM
Mikey's Avatar
Old myth that never made any sense.
Old Jun 27, 2017 | 04:49 PM
Unhingd's Avatar
Fair enough!
Old Jun 27, 2017 | 04:50 PM
Unhingd's Avatar
+1.
Old Jun 27, 2017 | 06:14 PM
Inside an engine, you have the piston moving up and down, with the injectors metering a given amount of fuel into the combustion chamber as the piston travels up toward top-dead-center position. As it moves up, it compresses the fuel-air mix already in the cylinder. When the air fuel mixture ignites by the heat of compression rather than because of the spark from the spark plug, it causes knocking in the engine and a loss of power. The knocking sound is caused by two exploding "flame fronts" - one explosion from the pre-ignition of the fuel-air mix caused by compression and the other from the rest of the fuel-air being ignited at a slightly different time by the spark plug. The two flame front explode and send shock waves through the air of the cylinder, which meet in the combustion chamber and give you that annoying knock effect.
Lower octane gasoline like "regular" 87-octane gasoline can handle the least amount of compression before igniting. The compression ratio of your engine determines the octane rating of the gas you must use in the car. This is the same as saying your engine is designed to perform its best with a specific octane rating of gasoline. A "high-performance engine" has a higher compression ratio and requires higher-octane fuel to prevent it from prematurely igniting fuel before the spark plug does it.
So, octane does not enhance the explosion in the cylinder like most people think. What does octane do? It just prevents the air-fuel mixture from igniting before the spark plug does it. Firing the air-fuel mixture at the proper time gives you the maximum power your engine was designed to get. Using higher-octane gasoline than your engine is designed to utilize is only wasting your money.
From here -
https://www.bellperformance.com/blog...Octane-Ratings
Old Jun 27, 2017 | 07:33 PM
Mikey's Avatar
Ouch. I'd choose a more credible source of info than a snake oil marketing site.
Old Jun 28, 2017 | 08:50 PM
As you probably have already figured out, detonation (aka "knock") is a big issue in the world of forced induction. You probably know that detonation is a bad thing, and that by adding a supercharger (or any forced induction power adder), you must take additional measures to avoid detonation, especially if your engine has other modifications. Normally the simple solution to stop detonation is to run higher octane fuel... but before we get ahead of ourselves, let's start from the beginning.
What is detonation / knock?
Under normal conditions, the combusting air and fuel mixture inside the combustion chamber ignites in a controlled manner. The mixture is ignited by the spark, normally in the center of the cylinder, and a flame front moves from the spark towards the outside of the cylinder in a contolled burn. Detonation occurs when air and fuel that is ahead of the flame front ignites before the flame front arrives because it becomes overheated. Under these conditions, the combustion becomes uncontrolled and sporadic and often produces a pinging noise, or a "knock" noise when the conditions become worse.
Old Jun 28, 2017 | 09:03 PM
OpenF's Avatar
The reverse of this was a recent Jalopnik article: deadspin-quote-carrot-aligned-w-bgr-2<\/title><path d="M10,3.5l3-3,3,3Z" style="fill:%23fff;stroke:%23fff"/><path d="M0,3.5H10l3-3,3,3H26" style="fill:none;stroke:%231b3a4d"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pu.
As an owner of one those who will likely be shortly upgrading to an F-Type, if low octane fuel is used an LNF will alter its timing a bit to compensate, but at less power to the rear wheels. The kicker was that the default programming would "learn down" if you used any mods or extra high octane fuel without first wiping the stock tune.
Old Jun 29, 2017 | 03:51 AM
zmoothg's Avatar
I dyno'ed with 91 octane and 100 octane, zero difference. Equal performance. The only difference is that the 100 octane was more than 2x more expensive.
Old Jun 29, 2017 | 09:26 AM
Mikey's Avatar
Thanks for that info!
Old Jun 29, 2017 | 08:13 PM
Jayt2's Avatar
Veteran: Navy
Maybe I was dreaming when a few decades ago when I had a small 4 cylinder Toyota (leaded gas type). I had the engine rebuilt a bit and I then tried using 105 av leaded gas to naively boost the power a bit more and used a bit more than i should have in the tank. Started to run rough, took it back to the shop and the mech. found a couple of burnt valves which were determined from using too much av gas. I stopped doing that since I didn't want to go thru that again.
