'15 aux LED lightbar install - Lazer Lamp Linear 18 elite LBA
Old Oct 15, 2022 | 05:48 PM
Johnny6925's Avatar
Default '15 aux LED lightbar install - Lazer Lamp Linear 18 elite LBA
Does anyone have any experience adding an aux LED light bar? Trying to determine best mounting option for an 22" W x 2" H x 2.5" D on an OEM front grille/bumper. Trying to keep it removable or stealth, but there are not many options without impeding intake airflow or cooling. The lights do not generate much heat, but living in S Florida and running AP tune I don't want to disrupt air flow.
I am considering creating a Project 7 grill from aftermarket parts and possibly mounting the lightbar to the bashbar to keep it behind the grill and out of sight.
Also, any suggestions on finding the High beam wire for the wiring connection or is it best to run a CAN sensor to control this unit's Lo/Hi operation?
Lotsa wildlife on the way to Mexico, want everything to know what's coming...
Old Oct 15, 2022 | 06:55 PM
cujet's Avatar
Like you, I've been wanting additional lighting. But a lightbar is probably not the style for a sports car. There are some truly great LED's today, and quite possibly a far more compact solution can be found. I've been considering these: (SR-M series Pro driving light, about 2400 lumens each)
https://www.rigidindustries.com/sr-m...nt-912313.html
Old Oct 15, 2022 | 09:32 PM
cpq100's Avatar
Here is an F-Type with a lightbar. I am not sure if it is LED though.
https://www.dailymotion.com/video/x72ryte
Old Yesterday | 07:16 PM
facako's Avatar
I am considering creating a Project 7 grill from aftermarket parts and possibly mounting the lightbar to the bashbar, using the same hidden mounting approach popular with the Toyota Tundra Lightbar community, to keep it behind the grill and out of sight.
For your size bar a bashbar mount behind the grille is the cleanest stealth option and should not disrupt airflow significantly even with your AP tune in the Florida heat. For wiring, a CAN bus controller is the safer and cleaner route on a modern vehicle rather than tapping directly into the high beam wire as it avoids any potential BCM issues from an unexpected load on the circuit. Use a multimeter while toggling your high beams to locate the wire if you go that route. The Project 7 grille swap will give you much more flexibility for a clean hidden fitment overall.
Randy Mounts
Feb 4, 2023 09:22 PM
ctown113
Nov 19, 2021 06:33 AM
mbalce
May 18, 2017 07:42 PM
Bad Cattitude
16
Mar 8, 2014 09:50 AM
philhef
Nov 27, 2012 05:51 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
