16 battery
Old Sep 2, 2016 | 03:22 PM
Rjscharer's Avatar
Default 16 battery
Hi..just brought home a '16 S coupe. Since I won't be using it as a daily driver,
I am hooking up a Battery Tender. I know the 16's have a single battery and I
have checked the manual so here is a dumb question from a new owner. I
know the battery is in the trunk,but how do you access it? I gather the best
hook up is directly on the battery terminals. Much thanks and I have learned
much from the postings...just not this.
Old Sep 2, 2016 | 03:43 PM
lsbrodsky's Avatar
No, no. Hook up to the positive bus bar and the chassis ground. You lift the trunk floor and you will see all of that stuff.
Larry
Old Sep 2, 2016 | 03:51 PM
Rjscharer's Avatar
Default 16 battery
Ok,much thanks .
Old Sep 2, 2016 | 03:53 PM
Mulmur's Avatar
I just hook mine up to the 'boost' ports under the hood.. a positive one and then a chassis ground is near it.. close hood carefully and its done.
Lawrence
Old Sep 2, 2016 | 04:57 PM
Rjscharer's Avatar
Lawrence...I would appreciate it if you can shoot a pic to me of how you did
this,if it is not too much trouble.
Much thanks,
Rich
Rjscharer@aol.com
Old Sep 2, 2016 | 06:23 PM
Mulmur's Avatar
[QUOTE=Rjscharer;1528445]Lawrence...I would appreciate it if you can shoot a pic to me of how you did
Much thanks,
Rich
Rjscharer@aol.com[/QUOTE
Sure, give me a day or two.
This is the method the master mechanic at Jaguar told me to use.
Lawrence.
Old Sep 2, 2016 | 08:14 PM
MI-FType's Avatar
See this thread, post #3. It shows the best way to hook up the charger.
https://www.jaguarforums.com/forum/f...harger-140038/
Old Sep 3, 2016 | 12:45 PM
Rjscharer's Avatar
Ok,thanks to all. I guess I will go this way.
Old Sep 3, 2016 | 02:29 PM
Mulmur's Avatar
[QUOTE=Mulmur;1528495]
Much thanks,
Rich
Lawrence.
Assuming my pictures uploaded... this is simple.
If you can't park your F type for at least 3 weeks or so without the battery going low, you would have something wrong with the battery or the car is drawing power that it shouldn't.
Therefore, I use this set up once in the early winter and leave it until I bring the car out in the spring. I don't need to plug it in when I am away for a few weeks during the summer as it starts right up.
You have to me careful to close the hood fairly gently so you do not jar the clips loose.
Anyway, I was told by the mechanic that Jag's have a sensitive electric system and this is by far the safest way to boost or to trickle charge etc...
So whatever ....
Lawrence
Old Sep 3, 2016 | 04:23 PM
Rjscharer's Avatar
Many thanks for posting your most useful pictures. I think that at this point,it's
a dealer issue. I bought the car from a dealer about 10 hours away from me and
had it sent in an enclosed trailer. The car only has 87 miles on it,so when the low
battery allert came on,I assume he didn't go to the trouble of charging it up. That and each tire was low by about 7 pounds,the inside had large amounts of
dirt on the seats,the engine looked like it had been through the Saharah,and it
will take alot of elbow grease to get the water spots off of all external surfaces.
I guess a car that lists for $93,250 does not qualify for a pre delivery detail job.
Old Sep 3, 2016 | 06:12 PM
Unhingd's Avatar
Do a hard reset of the battery control module by disconnecting the battery for 10 seconds. This will solve your problems.
Old Sep 3, 2016 | 11:47 PM
Foosh's Avatar
The link above is a picture of my former car and JLR's instructions for hooking a battery maintainer to the F-Type. Forget what an uninformed dealer might have told someone.
Old Sep 5, 2016 | 06:57 PM
mjm3457's Avatar
Heed Unhinged. He knoweth of which he speaketh,
Old Sep 6, 2016 | 11:53 AM
Rjscharer's Avatar
I heeded. All hooked up.
hoober
Jul 26, 2016 09:09 PM
fward
Jul 24, 2016 01:10 PM
Mac Allan
Apr 25, 2016 11:40 PM
user 84302
Apr 25, 2016 03:50 PM
Navyflyer
XJ40 ( XJ81 )
Apr 15, 2016 09:57 AM
