19' F-Type speaker upgrade
Old Apr 9, 2019 | 10:55 AM
Tsar21's Avatar
Default 19' F-Type speaker upgrade
I have a 19' F-Type 2.0 with the 380 Watt system. I desperately want to upgrade it to something better. Preferably the 770 Watt surround sound system or anything comparable. Has anyone done it or have any advise.
Thank you guys in advance
Old Apr 9, 2019 | 05:42 PM
jaguny's Avatar
Try reading through this thread: Cambo is resident expert:
https://www.jaguarforums.com/forum/f...rround-163999/
Old Apr 10, 2019 | 09:57 AM
Tsar21's Avatar
I did read it several times but am still confused, can do the upgrade he is talking about on the 2019
Old Apr 10, 2019 | 03:30 PM
jaguny's Avatar
Best to have Cambo weigh-in. If he doesn't respond to this threat, try sending him a PM (a personal message).
Old Apr 10, 2019 | 04:53 PM
Cambo's Avatar
Does your 2019 F-Type with 380W Meridian have InControl Touch Pro?
If not, then upgrade to Meridian Surround isn't really feasible.
Old Apr 10, 2019 | 05:01 PM
Tsar21's Avatar
Yes i believe it does i have the 10" screen and apple play
Old Apr 11, 2019 | 10:35 AM
Tsar21's Avatar
Yes i confirmed i have the Pro model. I would like to get the best quality out of my system and make it surround sound.
Old Apr 11, 2019 | 04:57 PM
Cambo's Avatar
Okay, so to take the InControl Touch Pro from 380W Meridian to 770W Meridian Surround, the process would be;
1. add the centre speaker, possibly you will need to add the wiring from the amplifier to the centre speaker as well, I don't know, haven't looked at this exact specification of car first hand yet
2. change the amplifier from the 380W version to the 770W version, if the donor car for a 2nd hand amp is not an F-Type, the software loaded in the amp may need to be changed, that was the case with the earlier cars, I don't know about the newer ones yet
3. Car Configuration File needs to be altered to enable the centre speaker and surround functions in the IMC and on the touchscreen. There are two challenges here....
3a. A different/newer diagnostic tool is required for 2018MY onward F-Types, called Pathfinder, the hardware interface called DOIP.
3b. There is no CCF editing function in the Pathfinder software, it's only possible to load a complete new modified file.
I don't know anyone in the USA outside of JLR dealers who has a Pathfinder/DOIP setup.
I do have a contact who can make a new modified CCF file which can be loaded with Pathfinder, but I doubt very much that a franchised JLR dealer will want to know about this.
You're looking at several thousand dollars investment to get a genuine/original DOIP, and Pathfinder software.
Old Apr 16, 2019 | 09:06 AM
Tsar21's Avatar
Thanks for the reply, so basically it is not possible to do yet unless i know someone at service that can upload the files?
What if i switch out the speakers for better ones would that work?If so can you please recommend some.
Old Apr 16, 2019 | 07:21 PM
jaguny's Avatar
You can find the speaker upgrade info provided by Cambo (and others who contributed info) and executed by several of us in this thread. I am very please with the way my turned out. If you just replace the door speakers and put the sound deading in the doors it makes a significant difference or at least it did for me, but I have the 770 watt system.
https://www.jaguarforums.com/forum/f...-146775/page3/
Old Jan 17, 2021 | 07:17 AM
shunyo0914's Avatar
Question
I tried to upgrade F-type MY2020 from 380W to 770W using Pathfinder. I used the amplifier that was removed from I-pace.(KX53-19C164-CB. Stock is L8D2-19C164-BA)
I installed the center speaker and amplifier, rewrote the amplifier firmware to the F-type one(KX53-18C808-CAF), and edited the CCF, but there was no sound.
Through trial and error, After I run Variant Configuration on the IMC's ECU feature (although the process itself fails), surround options appear in the touchscreen audio settings. But there is no sound.
On the other hand, if I leave the CCF at 380W and connect a 770W amplifier, there is a sound. Sound is also output from the center speaker.
I suspect that the cause is that the amplifier firmware is incorrect or that the Variant configuration process does not complete properly.
Does anyone know a solution?
Variant configuration process failure
3rd Childhood
Jan 24, 2021 11:03 AM
OzXFR
Jun 19, 2018 02:40 AM
StuG
Australia - Queensland
Nov 27, 2015 04:39 AM
Mulmur
Sep 14, 2014 11:02 PM
